How to winterize sprinkler pump
Discussion in 'Irrigation / Sprinkler Forum' started by lsc87, Oct 28, 2007.
  1. lsc87
    lsc87 New Member
    Jul 16, 2007
    I use a 1hp jet pump in my basement to supply water to a sprinkler system. I live in the northeast, so winter's coming. The sprinkler guy is coming to blow out the lines.
    What do I do with the Wayne jet pump over the winter? Right now there's still water in it. I will disconnect the supply line from the lake and blow it out. Do I need to get all the water out of the pump even though it wont' freeze?
    Also, will it hurt the pump if I don't use the sprinklers for a week or more in summer? The supply line retains prime, so there is always water sitting in the pump.
    thanks
    Doug
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    This is the best response I've ever given to this question:
    Pay a contractor who deals with these systems specific.
    Do it by contract whereby they winterize it, bring the system back up the following season. That way if anything done is improper and breaks something, it's going to be covered by the ones who did the work.
    You'd be surprised how cheap those companies will do this for.
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    Rugged is 100% right....
    have it done by a professional
    they will come out with a huge air comperessor
    hitched to the back of their truck...
    When they blow air through the system all your sprinkler
    heads will jump out of the ground at one time and look like
    old faithful going off....
    it usually only costs about $100 bucks...around here..
    and they warranty the work...
    you wont have to make any reapirs this spring
  5. theelviscerator
    theelviscerator New Member
    Oct 2, 2007
    Sales
    Elkhart, IN
    I made a rig out of a scott air pack bottle with a union to blow down a complex fountain system.
    Make sure you have one or two valves open when you start cracking open the bottle.
    (not recommended for the faint of heart).
    Dry as a bone though after completion...
  6. lsc87
    lsc87 New Member
    Jul 16, 2007
    Let me clarify, all the lines underground will be professionally blown out. I'm only asking about the pump. I guess it's pretty obvious I need to get all the water out of it. Next question is, if that's true, does the pump just sit there dry all winter?
    And what about going 2-3 weeks between uses (if it's rainy) when the water just sits in the pump? Any issue with that? Does it need to run every few days, or it can sit with water in it?
    thanks
    Doug
Similar Threads: winterize sprinkler
Irrigation / Sprinkler Forum Sprinkler system winterized when bought house - how to use?? Jun 6, 2011
Irrigation / Sprinkler Forum Sprinkler Winterize, Backflow Preventer dilemma Sep 21, 2010
Irrigation / Sprinkler Forum Winterize Sprinkler, where to hook up Air Compressor? Oct 28, 2009
Irrigation / Sprinkler Forum Who do I call to winterize my sprinklers? Oct 18, 2009
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Today at 3:14 PM
