How to tighten pipe replaced in middle of run
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by greymont, Jun 22, 2013.
  1. greymont
    greymont New Member
    Jun 22, 2013
    Massachusetts
    I'm replacing some pipe in my garage that feeds water to the sprinkler system and a garden hose faucet. I bought some galvanized 3/4 inch fittings that I can put together to fit the space. I started with the water feed pipe and inserted a T to branch to the sprinkler connection and also to the faucet pipe as it goes into the wall. The faucet pipe I can rotate to get the threads tight but the sprinkler connection is fixed, as is the water feed at the other end of the assembly.
    How do I tighten the pipe connecting to the sprinkler pipe? If I screw it into the final connection it unscrews from the other end!
    Is there a special connector to handle this?
  2. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    The fitting you need is a union.
  4. greymont
    greymont New Member
    Jun 22, 2013
    Massachusetts
    Ah, right you are. Didn't see union fittings before.
  5. sethamin
    sethamin New Member
    Feb 21, 2013
    Brooklyn, NY, United States
    You could also use a left-right fitting, where the threads are reversed on one side, but I think those are more typically used in gas lines where unions are not allowed.
Similar Threads: tighten pipe
Plumbing Forum, Professional & DIY Advice How and how much to tighten this pipe? Sep 5, 2016
Plumbing Forum, Professional & DIY Advice what are some tricks to tighten chrome/nickel etc pipes Feb 20, 2011
Plumbing Forum, Professional & DIY Advice How hard to tighten Black Iron pipe? Jul 29, 2009
Plumbing Forum, Professional & DIY Advice tighten shower pipe without scratching it ?? Mar 3, 2009
Plumbing Forum, Professional & DIY Advice Cannot tighten cartridge after disassembly Wednesday at 9:04 AM
