How to tighten loose shower pipe??
Discussion in 'Shower & Bathtub Forum & Blog' started by haasek, Jan 4, 2006.
  1. haasek
    haasek New Member
    Jan 4, 2006
    The water pipe for my shower is loose. When I pull the on/off knob forward to turn on the water - the entire plate pulls away from the tile - and breaks any new caulking seal I put in place. Is there an easy way to tighten down the pipe again short of cutting into the wall?
  2. jimbo
    jimbo Plumber
    The shower valve is supposed to be secured by clamp fasteners to the wood structure. Either they did not do this, or it came loose. You could remove the round trim escutcheon and see if you can access anything that way. Otherwise, see if you can access from the other side of that wall.
Similar Threads: tighten loose
Shower & Bathtub Forum & Blog This has turned into a mess.......can't tighten dome enough Jan 27, 2013
Shower & Bathtub Forum & Blog Could Not Tighten Shower Drain Nut W/Wrench....?? Aug 25, 2012
Shower & Bathtub Forum & Blog How do I tighten down tub faucets if the tile wont allow access? Sep 3, 2008
Shower & Bathtub Forum & Blog Hand tighten or with wrench Jul 3, 2006
Shower & Bathtub Forum & Blog New Shower Arm will not tighten Apr 4, 2005
