How to stop bathroom sink leak
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Scottc123, Apr 10, 2013.
  1. Scottc123
    Scottc123 New Member
    Dec 30, 2012
    Long Beach
    Hello,
    I just installed a new sink and vanity, I'm having one annoying issue: the long (approx 8") portion at the end of the P-trap which goes into the wall is leaking where it meets the metal drain pipe coming from the wall (small drip from bottom where they meet). There are no fittings at this part just a straight 6" of PVC which fits snugly into the metal pipe coming from the wall, so I'm confused on how to stop this leak. Is there something that I can wrap around the PVC? It is super tight as is now so I am not sure what would work....
    Anyway any help would be appreciated, thanks
  2. 6t7gto
    6t7gto DIY Junior Member
    Jan 20, 2010
    Bedford, Ohio
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    If the pipe is 1-1/2 galvanized you need a slip joint washer and lock nut.
  5. hj
    quote; If the pipe is 1-1/2 galvanized you need a slip joint washer and lock nut.
    That is about the best way to guarantee that the end of the galvanized pipe will "rust away". Use a brass female trap adapter and prevent it from happening.
  6. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    How would a brass female adapter be any better than a brass brass or plastic slip nut?
    John
Similar Threads: stop bathroom
Plumbing Forum, Professional & DIY Advice Angle stop valves for bathroom sink Mar 20, 2008
Plumbing Forum, Professional & DIY Advice "Push" Faucets in Bathroom Will Not Stop Mar 1, 2006
Plumbing Forum, Professional & DIY Advice Acid Neutralizer won't stop draining Saturday at 5:31 PM
Plumbing Forum, Professional & DIY Advice Supply Line Pipe Type & New Stop Valve Feb 26, 2017
Plumbing Forum, Professional & DIY Advice 3/8 or 1/2 supply angle stops... what do you use? Jan 9, 2017
