CHH
RUGGED said:jip jip foo
Is that yes, no, or maybe?
speedbump said:When doing the bread trick always use Whole Wheat, it's lower in Carbs
Richard'sRenu said:I was at the latest Big Box store- and they had a "Plumber's Bread." It's made from corn starch and supposedly completly dissolves in a couple minutes.
Anybody used this stuff?
Richard
1st - dissassemble the valve - take all the guts out so you don't overheat them...biffrennie said:When I install and solder in the shower valve: Should I lay it all out flat on the floor and solder the joints and then put it up and make a connection with couplers down lower?? Or just solder the joints up in the wall? And if so, do you start soldering at the valve and work your way out or what?
About how much heat will it take to flow solder into the female connection port of the heavier valve body?? 3 seconds, 7 seconds, 20 seconds??
I would guess it's going to take alot more heat on that thicker material of the valve body.. correct???
most usually stub 1/2" copper with a hard solder cap on out of the wall then wait for the cabinets etc to be done...biffrennie said:And for the sink faucet:
How do you stub out the hot and cold supply from the wall for the sink faucet before the sheetrocker comes and hangs the drywall?? Do you just put in a 3" long nipple and cap it until he's done taping and texturing and then put on your shut off valve??
And do the same for the drain?
