tmy23
Greetings. Installing new Kohler toilet in a new bathroom with mosiac marble tile floor. Well my tile work must not be precise, because after snugging the toilet down, I noticed is has a slight wobble on what must be an uneven floor. As it's porcelain on marble, the rattle is "solid/loud", anyway, I was wondering what I can do to shim it? Can remove the toilet, put a bead of silicon under the footprint of the toilet and reinstall? Also do I need to replace the (brand new as it turns out) wax ring if I lift the toilet off to shim it? Can I shim it in place?I'm a little leary of wooden shims, are there rubber or plastic shims I can wedge underneath so I don't have to lift it? the gap is very slight, maybe 1/16-1/8, but enough to move it. thanks!!
