How to secure pvc going through a wall?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mckeand13, Aug 21, 2007.
  1. mckeand13
    mckeand13 Engineer
    Jan 27, 2007
    Engineer
    Orono, MN
    I installed a new sump pump in my moms house recently. I had to make a hole through the outside wall to run the drain outside as there wasn't an existing hole. It's a split entry home so the block wall isn't very high. I had to go through the sheetrock and out through the siding with the 1.5" pvc drain.
    My question is, how do I secure that pipe somehow? I need a way to clamp it to the wall so it's not able to slide in and out.
    Any suggestions?
    Thanks.
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I'd use caulking or expandable foam in the 2 holes where the pipe enters and exits the wall.
  4. mckeand13
    mckeand13 Engineer
    Jan 27, 2007
    Engineer
    Orono, MN
    I need something more rigid. It's in a place where it could easily be bumped and there's no caulk in the world that's going to keep it from sliding. The fact that the check valve is a flexible rubber coupling makes it very easy to move as well.
  5. mckeand13
    mckeand13 Engineer
    Jan 27, 2007
    Engineer
    Orono, MN
    Just had a thought.
    Screw a 2x4 across the studs that are running on either side of the pipe and just touching the bottom side of the pipe. I can then use a single or double sided clamp to hold the pipe.
    Sound logical?
  6. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    While you are still messing with the piping...
    Get rid of the rubber check valve - replace it with a hard plastic one...(unless you don't care if your mom's place gets flooded when the check gives out and the sump starts spraying into the basement)
    For anchoring, you can use 2-hole straps and bracing as was suggested.
  7. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Try a suspension pipe clamp....
    PipeClamps
    OK, for some reason the link keeps getting blocked. Do a search for suspension pipe clamps.
  8. mckeand13
    mckeand13 Engineer
    Jan 27, 2007
    Engineer
    Orono, MN
    Apparently this link isn't working. Can you spell it out or re-link?
  9. mckeand13
    mckeand13 Engineer
    Jan 27, 2007
    Engineer
    Orono, MN
    Just wondering what you mean. Are you saying the rubber may crack/split/separate, or that the hose clamp would loosen up?
    Couldn't you say the same about a fernco rubber coupler as well then?
  10. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Sent you a PM.
Similar Threads: secure going
Plumbing Forum, Professional & DIY Advice Need help to secure a two-hole kitchen faucet Aug 28, 2013
Plumbing Forum, Professional & DIY Advice How to secure black iron at the wall penetration Aug 19, 2010
Plumbing Forum, Professional & DIY Advice Can I secure a gas line to an exterior wall? Jul 15, 2010
Plumbing Forum, Professional & DIY Advice How secure hose bib to hardi plank Jul 8, 2010
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Feb 19, 2017
