How to replace a copper fitting close to another fitting
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jfhardy, Nov 26, 2008.
  1. jfhardy
    jfhardy New Member
    Oct 31, 2008
    Sorry for the duplicate post. I posted this in the remodel forum when I should have posted in plumbing.
    I am working on a basement finish and I have just completed installing ¾ inch hot and cold copper supply lines for a new bathroom. I installed shutoffs before putting in the supply lines. I just turned on the water to pressurize the lines and I have 1 leak. There is a 90 degree elbow about 1 inch from the shut off in the hot supply line. The joint in the fitting on the shut-off side is the leaker. So now I think I need to:
    1) drain the lines
    2) heat up that fitting and take it apart
    3) clean the pipe up, removing all of the old solder
    4) re-solder in a new fitting
    My question is will I compromise the soldered joint in the shutoff (that is only one inch away) when I heat and take apart the fitting I need to replace? Are there any steps I can take to protect the nearby soldered joint before heating up the one I need to take apart? I am an amateur and I have never taken apart a soldered fitting before. Any advice would be appreciated.
    Thanks, Jack
  2. Terry
    Aug 17, 2004
    Heating are reheating is fine.
    You can put a damp rag on the part that is done too.
Similar Threads: replace copper
Plumbing Forum, Professional & DIY Advice Should I replace copper pipe? Mar 14, 2017
Plumbing Forum, Professional & DIY Advice Proper replacement for a disintegrated copper cleanout seal? Sep 8, 2016
Plumbing Forum, Professional & DIY Advice Slip-on spout adapter's set screw DESTROYED my copper pipe - how to replace the pipe or alternative? Jul 9, 2014
Plumbing Forum, Professional & DIY Advice Need to replace copper drain pipes in Basement Mar 30, 2014
Plumbing Forum, Professional & DIY Advice Brass to Copper Replacement May 15, 2013
