How to replace a candelabra socket in an outdoor light
Discussion in 'Electrical Forum discussion & Blog' started by jeff_bathroom, Oct 27, 2008.
  1. jeff_bathroom
    jeff_bathroom Member
    Dec 15, 2005
    Florida
    Hi,
    Rather than buying new outdoor light fixtures, I've been revamping the old brass ones; cleaning them up nice.
    However I have two lights; one at the front door and one at the garage door whose sockets don't work. There are multiple bulbs in each fixture and at least one other work in the fixture.
    Is it feasible to replace the bad sockets? If so, where do I get them and what do I ask for ?
    tip : about cleaning the brass - half white vinegar/half water and a tablespoon or two of salt. Bring to a boil. Pour over the fixtures in another container. Leave in for a couple hours. Just a little scrubbing afterwards with a course nylon pad. Spray four to six coats of clear lacquer on them, then re-install.
  2. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Somebody put the fixtures together so generally, you can take them apart.
    Take them down turn the upside down and blow all the dirt and dead bug parts out. Sometimes this is enough to get them running again.
    Better yet, use some CO2 in a can (keyboard cleaner) and you won't have to take them down.
    If you feel that you want to replace the sockets, just look at how they are attached and unattach them ;)
  4. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    Any good local hardware store should have replacement lamp parts. Take the old ones out and bring them with you to match up.
  5. jeff_bathroom
    Dec 15, 2005
    Florida
    Thanks guys. I will be taking them apart because I will be cleaning them using the method noted above.
    Southern man; that's what I needed to know; whether I can get replacements. 220/221, I'll trying cleaning them off good before I needlessly replace them though.
    Thanks again for your help ! :)
Similar Threads: replace candelabra
Electrical Forum discussion & Blog GFCI replaced, now regular outlet is dead Feb 14, 2016
Electrical Forum discussion & Blog Can horizontal radiant heaters be replaced with in wall units? Nov 12, 2015
Electrical Forum discussion & Blog Dual Trip Breaker Replacement Jan 25, 2015
Electrical Forum discussion & Blog Electric Motor - ID / replacement help Jan 23, 2015
Electrical Forum discussion & Blog electronic ignition fireplace won't start when lights are on Mar 7, 2014
