I need to move a toilet to a different location and to do this, I need to cut out a section of 4" pipe that has a fitting in it and replace it with just straight pipe. But there isn't any flex in the pipe at all to be able to use two standard couplings. Would you recommend using a standard coupling and one of the flexible rubber coupling or should I attempt to use a repair coupling and slide it on before the glue dries?
Thanks in advance for your suggestions!
