How to remove TOTO Ultramax flapper. THU096
Discussion in 'Toilet Forum discussions' started by Watersprite, Dec 23, 2013.
  1. Watersprite
    Watersprite New Member
    Jun 3, 2011
    Alexandria, VA
    My one-piece Toto Ultramax (CST 853S) needs a new flapper. I have done this many times before on other toilets and it is an easy task. HOWEVER, on this one, the pink flapper is connected to an L-shaped piece of plastic but there is NO WAY TO GET IT OFF. The flapper connector is attached the plastic L-piece without a break. In other words, it is solid plastic. How do I get it off to put in a new flapper? (And...WHAT was Toto thinking???)
    Thanks.
  2. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    The pink flapper is made of a rubber-like compound. Just unhook the female part of the flapper from the male hook on the flush valve by pulling it across the base of the T and then up the hook and off. This video involves a flapper smaller than the one on your Toto, but the process of removal is the same. A few seconds in you can see how to take the old one off. On the video, they remove the flapper at about 33 seconds into the video...
  4. Terry
    Aug 17, 2004
    Takes me a few seconds. They clip on and clip off. :)
  5. Watersprite
    Jun 3, 2011
    Alexandria, VA
    Thanks for your replies, but... I would be able to do this if the flapper were soft rubber (and have done so many times). But where it is connected to the bar, this flapper is SOLID HARD PLASTIC all around and there is no way to slide it off or slide it any other direction. I just called Toto and they said I had to cut it off! What??? (And I need to buy a cutting tool [dykes] to do it.) There has to be an easier way. The support rep at Toto even had to check with his supervisor. Ever heard of this?
  6. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
  7. Terry
    Aug 17, 2004
    I may need a picture of that. The hard plastic one that I'm aware of lifts straight up.
    [​IMG]
    The hard plastic one from about ten years ago lifts off the pins straight up. It can be replaced with the new rubber flappers, or there is a rubber disk that can be replaced on the underside of the flat plastic flapper assembly.
    [​IMG]
    The old style above. This has the old Hunter fill valve, and notice that the refill tube needs to be pointed down the overflow tube.
    THU096 disc for older style TOTO Ultramax flush valve.
    http://www.nyrpcorp.com/toto-flapper-thu096
    [​IMG]
    Newer style with the ears.
  8. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Do us a favor and post a picture if you can. Then we'll know what we're dealing with.
  9. Watersprite
    Jun 3, 2011
    Alexandria, VA
    OK -- Here are two photos. BTW, I bought this toilet two years ago.
  10. Terry
    Aug 17, 2004
    The flapper lifts off the pins. You angle it up a bit as you slide it off.
    That flapper is very easy to remove and replace. We sometimes, with the customer there show them how easy it is to remove and replace.
    Here's a hint. Rubber bends.
  11. jadnashua
    The pin has an asymmetrical nub, as does the opening in the flapper. It's easier to take off when you lift the flapper up some to align the long ear of the nubs and the slot in the flapper itself.
  12. Watersprite
    Jun 3, 2011
    Alexandria, VA
    Thanks for all help from everyone! I did manage to remove the flapper, but it was far from easy. Tight access to the tank and very little room inside to work -- I couldn't get the handle off, so had to maneuver around it. The Korky is so easy to install -- why can't Toto be the same? Anyway, all is now well.
    My hat's off to all of you in this business. Thank you again.
  13. Starwarsith88
    Starwarsith88 DIY kid who loves toilets
    Aug 20, 2013
    Sparta NJ
    I wonder where the person dug that hunter fill valve out of!
  14. Terry
    Aug 17, 2004
    The original Ultimate came with that valve.
    Same parts as the Korky. Korky bought them out.
Similar Threads: remove TOTO
Toilet Forum discussions Remove stubborn Toto toilet seat Oct 12, 2014
Toilet Forum discussions What do you use to removed recessed nut on Toto Ultramax? Feb 17, 2012
Toilet Forum discussions Space Needed to Lift/Remove Tank Lid On Toto UltraMax II (Gwyneth 1-piece) Jun 29, 2009
Toilet Forum discussions Remove or Replace Toto Soft Close Lid? Mar 11, 2009
Toilet Forum discussions Pulling toilet - should I remove the tank? Can I reuse the tank to bowl seal? Mar 7, 2016
