How to remove this... glue?
Discussion in 'Remodel Forum & Blog' started by azkyle, Mar 12, 2007.
  1. azkyle
    azkyle New Member
    Sep 1, 2006
    I am taking down an addition someone put up on this house a while ago. As you can see they were not pros.. I'm not sure what this is, but I need some suggestions on the best way to remove it. They used tons of this glue, and nails, to haing this stuff up to cover the brick. I want to try to take as much off as possible without ruining the brick so i can paint it.
    Thanks in advance.
    [​IMG]
    [​IMG]
    [​IMG]
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    It looks like the brick was painted. Try a good paint remover to take everything off. You might try several different types. F505 seems to work for me.
    Since it is brick, you might try a torch with a good flame spreader.
  4. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    might be FRP adhesive but looks kinda like cutback. Torch or heat gun to soften it up then scraper & wire brush. Hope you have plenty of time on your hands... good luck...get plenty of gloves, I hate blisters.
  5. Dan Pick
    Dan Pick New Member
    Feb 11, 2007
    Plumbing Sales
    Speedway, IN
    Opportunities........
    Looks like old Mastic, if thats the case it is easier to knock down the brick wall and rebuild it.
    It could also be construction adhesive and in that case I have had good luck with a heat gun and a putty knife or wire brush.
    Let us know your progress and good luck
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Try a small putty knife and a hammer to tap it with and see what happens, it may not be as bad as it looks sometimes that stuff almost falls off other times it is a bear.
    When you get off as much of it as you can, if you still don't like it and the wall is always dry, never damp you can skim coat it with drywall mud then paint. You could texture it a little and /or do a faux paint finish to hide the roughness
  7. Randyj
    Nov 25, 2006
    Alabama
    If ya just want to have fun with it get a auto body grinder with about a 20 grit disc, knocks it down pretty quick and you can do fancy patterns with the grinder.. makes a heck of a dusty mess.
  8. azkyle
    azkyle New Member
    Sep 1, 2006
    thx for the replies.. i tried the torch, but i'd probably go through about 20 cans of gas before its done so i got a heat gun... it works good but the progress will be quite slow. so maybe ill be done by next week haha. thanks for the help.
Similar Threads: remove glue
Remodel Forum & Blog Remove foil from one side? Dec 11, 2013
Remodel Forum & Blog How much of the old fireplace can I remove? Aug 19, 2013
Remodel Forum & Blog Recessed Wood Framed Mirror -- how to remove caulk without damage? Oct 23, 2012
Remodel Forum & Blog Garage Door Wall Button Console - How to Open or Remove? (photos) Jul 30, 2012
Remodel Forum & Blog Attic Blown In Insulation Remove Or Blow More Over It ? Feb 5, 2012
