How to remove long-time residue from stick-on no-slip decals
Discussion in 'Shower & Bathtub Forum & Blog' started by KarenTheBold, Sep 12, 2013.
  1. KarenTheBold
    KarenTheBold New Member
    Nov 5, 2004
    California
    Years ago when I rented out my home, the tenant stuck on no-skid decals on the bottom of my bathtub. (Ceramic bathtub installed in 1948.) I removed the decals as best I could, but there are still rough spots in the tub that also catch dirt, residue from the stick-um on the decals.
    Is there a way to remove this residue? (I'm not interested in tearing out the tub, which would mean having to remodel every part of the bathroom. The bathroom is now only used for guests.)
  2. jadnashua
    Try something like GooGone. There are several other similar products, but this one is pretty good at this sort of stuff (mostly natural ingredients). Readily available lots of places and not very expensive. Acetone might work - be careful with the stuff as it is absorbed through your skin, and it smells funky. Use gloves and good ventilation. Something like the Mr Clean Eraser might help getting the last of it up.
  4. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Xeylene is a smelly awful stuff. It does however remove so much sticky stuff.
    It is the main ingredient in goo gone and sometimes easier and cheaper to find.
    JW
  5. KarenTheBold
    Nov 5, 2004
    California
    Clarification: The residue isn't sticky. In fact it is dry and just gritty enough to trap stains and look bad.
    Thanks for the advice so far--I just want to explain the nature of the residue, before I go buy "serious" chemicals that may not address the current situation.
    What do you think?
  6. jadnashua
    I think John was confusing Goo Off with Goo Gone. GooGone is mostly citrus based. It's not very expensive, and handy to have around - I'd give it a try.
  7. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    What Jim said.
    I was thinking of the smelly Goof Off product. Never tried the citrus version.
  8. Terry
    Aug 17, 2004
    Use a razor blade on it. Sometimes we pull the blade out of a box knife and use that.
  9. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    Just to add to that:
    Keep the area wet and scrape in a very small angle so you don't scorch the tub. Work slowly.
  10. KarenTheBold
    Nov 5, 2004
    California
    I appreciate you who provided suggestions. Terry, I'm honored you weighed in too. I'll report back on what works.
    I do have a concern that the tub surface is already a bit rough, perhaps due to using abrasive stuff like Ajax in the past both for cleaning (in the three decades before I bought the house plus seven years of tenants) and then my own efforts to remove traces of the decals.
  11. jadnashua
    I'd try some Goo Gone first to soften things up, then see what happens. Saturate a paper towel and leave it on the area overnight, then see what happens...cheap, and the stuff is handy to have around to get sticky residue off things. It will soften a lot of things. The fact the adhesive is hard may not be a big deal...it was soft, and the Goo Gone should help make it that way again, and then I'd try scraping off what's left.
Similar Threads: remove long-time
Shower & Bathtub Forum & Blog Roman Tub/Drain...Want to Remove Feb 20, 2017
Shower & Bathtub Forum & Blog How do I remove these bathtub skirt panels? Feb 16, 2017
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog What is this part and why can't I remove it? (Moen shower 1225) Mar 31, 2016
Shower & Bathtub Forum & Blog Reinstalling acrylic tub with feet removed? Mar 22, 2016
