how to remove kitchen tap
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by LindaK, Jan 13, 2014.
  1. LindaK
    LindaK New Member
    Sep 29, 2013
    BC, Canada
    I'm trying to remove a kitchen tap and having problems. Underneath the sink the waterlines and spray hose etc come out of the tap base but are all surrounded 3/4 of the way by a metal circular sheath (for lack of a better term) that is about an inch long. There is a nut way up inside of this metal sheath but I cant get to it to unscrew it. Can I remove the metal sheath in some way? HELP!!!
  2. hj
    No way to tell you without a photo. But if it is a Moen valve with the "adapter" turned upside down because of the counter thickness, then you may need the special wrench that came with it and someone probably took with them or threw away.
  4. LindaK
    LindaK New Member
    Sep 29, 2013
    BC, Canada
    Thanks! My son says he has a friend who is in plumbing and may have one. Why do companies make things that take "special" tools. Ugghhhh
  5. hj
    It's an "engineer" thing. They like to show how smart the are by making the "best mounting they have ever seen", then make the special wrench to fit it, which then turns out to be a "single use tool" when it gets lost.
  6. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    Another way to look at it is that the need for special tools is often a deterant so DIYers will have to call in a real plumber, or pump guy, or electrician, or auto mechanic, or appliance tech......and I like it that way.
  7. hj
    Do you REALLY think an "engineer" is that intelligent, or even worries about what happens once he has designed it? They assemble their "brainchild" on a bench in a pristine laboratory, and have NO IDEA what it will take to install it in the field.
  8. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Could it be that the hoses are part of a replaceable assembly? Is that metal sheath OD larger or smaller than the holes in the sink?
Similar Threads: remove kitchen
Plumbing Forum, Professional & DIY Advice How do I Remove kitchen faucett? Sep 14, 2011
Plumbing Forum, Professional & DIY Advice Kitchen Faucet Moen 7730 - how to remove handle Aug 25, 2009
Plumbing Forum, Professional & DIY Advice How to remove this kitchen faucet? Sep 9, 2008
Plumbing Forum, Professional & DIY Advice How NOT to remove your old kitchen sink Oct 7, 2005
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Monday at 9:32 AM
