How to remove Grohe Sinfonia Faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by atulc, Mar 30, 2011.
  1. atulc
    atulc New Member
    Mar 18, 2011
    Metro NYC
    I need to replace the cartridge in my Grohe 20.655 Sinfonia two-handle lavatory wideset. This requires removal of the cross handle 1 and cap 5 (see the diagram and parts list). It is straight forward to remove the cross handle. But I can't figure out how to remove the cap.
    Grohe tech support recommended a strap wrench. I've tried, but the strap wrench keeps slipping because of the bell shape of the cap. As a last resort, I'd have to loosen the nut under the sink. But it is very crowded under the sink and I want to avoid this route. Any suggestions on how to unscrew the cap? Thanks.
  2. hj
    Wrap it with black electrical tape and use a good pair of Channelock pliers. Removing the faucet would not help at all.
  4. atulc
    atulc New Member
    Mar 18, 2011
    Metro NYC
    HJ - thanks, I'll try out the electrical tape and channel lock pliers.
    Sorry, I didn't mean to remove the faucet but just the handle and cap. Thanks for correcting that.
  5. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Man I hate Grohe, heh. That escutcheon should unscrew. Hj's method will certainly give you a good grip, but you have to careful with how much squeezing force you apply. Another way to go is to wear gloves with a special rubber grip coating applied to the underside...that will allow your fingers to get a good grip if you can't get a rubber strap wrench on there.
  6. atulc
    atulc New Member
    Mar 18, 2011
    Metro NYC
    Finally got the cap off by wrapping it in plenty of electrical tape and using channel lock pliers. I can see now why it was so hard to unscrew - the cartridge and the inside of the cap are heavily corroded. Now to the next challenge - despite removing the cap, I can't get the cartridge out. It's frozen inside the housing due to corrosion. Time to call Grohe for more warranty parts.
    Basement_lurker - agree with your sentiment.
Similar Threads: remove Grohe
Plumbing Forum, Professional & DIY Advice Cannot remove Grohe single-lever faucet handle May 30, 2016
Plumbing Forum, Professional & DIY Advice Grohe Bathroom Faucet - How to remove cartridge?? Dec 10, 2012
Plumbing Forum, Professional & DIY Advice How do I remove this Grohe part Nov 1, 2011
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Yesterday at 9:32 AM
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Wednesday at 10:36 PM
