How to remove bowl with rusted bolts?
Discussion in 'Toilet Forum discussions' started by Bratan, Mar 23, 2013.
  1. Bratan
    Bratan Member
    Feb 16, 2013
    New York
    I'm trying to remove old toilet bowl (lower part) from the floor but two bolts/nuts are rusted and turn freely (both bolt and nut) :confused:
    How do I remove it? It doesn't go high enough for me to use hacksaw or dremel. I'm thinking of just breaking ceramic parts of the toilet near those bolts, but afraid whole bowl might crack. I will throw it out anyway...
    Would love any advise! :)
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    If you break it there will be no way to reset it. Haven't seen one yet that I couldn't get a hacksaw blade under.
    John
  4. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    I would think that you could clean that schmutz away from the nut and hacksaw or dremel through both. Also, why not Dremel the nut vertically, in two locations then just peel it back off the screw? I have done that more than once.
    If you are going to dispose of the toilet bowl anyway, just hit the china with a hammer right next to the bolt. It most likely will not crack the bowl above, just the area around the bolt. However, it wouldn't hurt to plunge out the preponderance of what's in the bowl beforehand, just in case.
  5. Terry
    Aug 17, 2004
    You can saw the nut on the top side and then split it off. Most people assume it has to be cut horizontal to the floor. You can also cut down on the nut from the top.
    Or if you don't mind scratching the porceling, a sawzall and lean into it.
    Or if the bowl is toast anyway, you can tap out the porcelain around the bolt with a hammer. (eye protection) You will have sharp glass edges that can slice, so be careful with any broken porcelain.
  6. Bratan
    Bratan Member
    Feb 16, 2013
    New York
    Thank you Terry and all! :) I used hacksaw at 45 degree angle and was able to remove both bolts (took me about 40 minutes of sawing hammering and bending) :)
  7. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Glad it worked out!
  8. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Hope there was a lesson learned here. Next time, use brass or stainless steel flange nuts, washers, and bolts.
  9. Terry
    Aug 17, 2004
    That's why we lock them down at the flange. I buy bolt sets with four washers and nuts.
    The home centers don't sell them that way, but it's how the plumbers buy them.
  10. wptski
    wptski Retired Machine Repairman
    Oct 20, 2012
    Warren, MI
    I used an oscillating tool on mine since I was replacing the toilet anyway.
  11. Bratan
    Bratan Member
    Feb 16, 2013
    New York
    That's a good idea! I will probably install it like that, flange is a little banged up...
    Yeah for whoever built this house in 1970 :) I only lived here for 5 years, and every time I do something I find nasty surprises :) Like double linoleum with tar sandwiched between layers :rolleyes:
  12. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    The tar is, tar paper which was common practice when the linoleum was put in.
    John
Similar Threads: remove bowl
Toilet Forum discussions Pulling toilet - should I remove the tank? Can I reuse the tank to bowl seal? Mar 7, 2016
Toilet Forum discussions Remove bowl to replace seat???? May 27, 2009
Toilet Forum discussions How to Remove this Rusty Toilet Flange Aug 4, 2016
Toilet Forum discussions Porcher Veneto -- how to remove a part? Jul 10, 2016
Toilet Forum discussions New product - ventilator removes odors at the toilet Jan 25, 2016
