how to remove abs shower drain ?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pman626, Jun 8, 2011.
  1. pman626
    pman626 New Member
    Jun 8, 2011
    Los Angeles
    I need to remove the top part of the shower drain because it is sticking out above the shower pan, and water is leaking under the drain lip.
    but it's tight as hell, mostly because I can't get a grip on it.
    I don't have the right tools at the moment. But do i have to remove the compression nut first? and then the rest of the drain assembly will twist off ?
    also, is the black pipe usually glued to the white drain assembly? Or is there only a rubber gasket between the black pipe and the drain assembly?
    how exactly is the pipe connected to the drain assembly?
  2. hj
    You have to remove the bottom locknut BEFORE the drain can be moved, or removed. There should be a gasket between the pipe and the drain, although I cannot see one, and the pipe MAY pull out of the rubber gasket once the drain is loose, otherwise you have to pry it out.
  4. Terry
    Aug 17, 2004
    I use a saw, or hack saw blade to make two cuts through the drain at the top; being careful to not cut into the shower pan.
    This allows me to pull the drain up, the locking nut underneath can slip off of the threads that way.
Similar Threads: remove shower
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Hi I have an older Moen shower handle I need to remove. Oct 23, 2016
Plumbing Forum, Professional & DIY Advice How to Remove Kohler Shower Valve Handle Sep 29, 2016
Plumbing Forum, Professional & DIY Advice Trying to remove the Faceplate on a Kohler Shower Faucet. Tried Everything. Help! Jul 18, 2016
Plumbing Forum, Professional & DIY Advice Cannot Remove Shower Handle After Removing Center Screw Jun 21, 2016
