how to refill and hot water system
Discussion in 'HVAC Heating & Cooling' started by chuckdiy, Jan 24, 2010.
  1. chuckdiy
    chuckdiy New Member
    Jan 15, 2010
    MA
    I have a pumped hot water monoflow system with 8 convector radiators. I'll be draining the system so that I can move some of the existing pipes around. Draining the system seems pretty straight-forward to me (but if anyone has any tips, I would certainly appreciate them). However, I don't know what the process is for refilling the system? How to I make sure all of the air is out. Can someone help?
    I'm thinking that I would just open the bleeders on each of the convectors then start to put water into the system. Then just wait until each of the bleeders spews water. Is that effective? There is an Air Scoop on the system, but I don't know how much air it is designed to remove. I should mention that I don't think the expansion tank has a bladder in it (old style)....it's a system that was done in 1960. Do I have to do anything with the Air Scoop during the process?
    Any and all help is much appreciated!
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    yep, that's it
  4. chuckdiy
    chuckdiy New Member
    Jan 15, 2010
    MA
    Thanks. One follow-up. Do I have to emty the expansion tank during (or before) this refill process?
  5. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    No you don't have to empty the tank but as long as you have the system down it would be a good time to drain it. It should be done yearly.
    John
  6. aksavarna
    aksavarna New Member
    Feb 1, 2010
    New Delhi
Similar Threads: refill water
HVAC Heating & Cooling Radiant heat and domestic water on same system? Feb 13, 2017
HVAC Heating & Cooling Indirect Hot water is Yellow Feb 8, 2017
HVAC Heating & Cooling Circulated hot water pros and cons Apr 10, 2016
HVAC Heating & Cooling Adding inline filter between water heater and humidifier? Nov 6, 2015
HVAC Heating & Cooling Hot water baseboard heater in basement - install Oct 11, 2015
