How to plumb drain for this.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by thinkly, May 14, 2013.
  1. thinkly
    thinkly New Member
    May 21, 2008
    Kansas
    I am switching from a double bowl to a single bowl sink. The garbage disposal will move to the center of the sink/cabinet. What PVC connectors shall I use to best complete this? Notice the drain comes out of the wall at an angle. Thanks for any help.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Chances are that to do it right the bend off the wall will have to be cut off. If it's PVC in the wall, the tee might can be bored out with a ram-bit so that a new trap adapter can be installed at the wall.
  4. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    I had similar situation to you. Went from double bowl to single bowl. we had to cut the stub out and and a 45 before the trap adaptor to get things to line up. looks like you may need to eliminate your 45.
    Here are the before pics. Note the stub out is coming straight out of wall.
  5. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    Here are the after photos when single bowl sink was installed.
Similar Threads: plumb drain
Plumbing Forum, Professional & DIY Advice Plumbing drains Mar 10, 2017
Plumbing Forum, Professional & DIY Advice Plumb Drain Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Updating laundry plumbing - vent and drain pipes Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Raising sink drain pipes to fit new vanity plumbing area Jun 30, 2016
Plumbing Forum, Professional & DIY Advice Plumbing Basement Drain Dec 28, 2015
