How to pick right size taco pump
Discussion in 'HVAC Heating & Cooling' started by JOE1934, Jun 7, 2007.
  1. JOE1934
    JOE1934 New Member
    Jun 3, 2007
    New York
    I'm going to have 3 separate pumps for 3 zones,BB hot water,gas. Do you establish a flow rate for each zone (f=Q/500 X 20) (http://www.taco-hvac.com/uploads/FileLibrary/SelectingCirculators.pdf). The f that you get,you are suppose to go to the chart and tells you the size of pipe. Is this pipe size the size that is suppose to go into the pump and or the pipe going out of the pump.
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    It is the size of the pipe/tubing in the circuit. In most cases the pump will be the same size but could be larger.
Similar Threads: pick right
HVAC Heating & Cooling Picking the right cast iron radiator Dec 31, 2009
HVAC Heating & Cooling Help in Picking Replacement Central HVAC system Nov 24, 2016
HVAC Heating & Cooling Reworking Radiant Heating Zones. Does this look right to you? Sep 30, 2010
HVAC Heating & Cooling Right Filter for a Lennox 26-21-1 Furnace? Nov 29, 2009
HVAC Heating & Cooling choosing the right size modulating furnace Apr 25, 2008
