How to make the test ball seal better
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by waltsyd, Jan 15, 2013.
  1. waltsyd
    waltsyd New Member
    Nov 29, 2012
    Three Rivers, CA
    The new 4" test ball is letting water past, very slowly but enough to invalidate the hydrostatic test. I can see every joint but not the test ball (it's in a sealed wye) so I know it's the test ball. I've drained and repositioned plug three times. It's a little better but still leaks slowly. So what do you think of slathering some rectorseal or something else on the plug before inserting? Might harm the rubber? Any other ideas?
  2. hj
    If you slide it in far enough to be inside the pipe, not a fitting, it will seal when you use enough air pressure.
  4. Terry
    Aug 17, 2004
    These are nice
    [​IMG]
  5. waltsyd
    waltsyd New Member
    Nov 29, 2012
    Three Rivers, CA
    solved
    Forgot I hadn't posted that the problem was solved. There was a very slow leak at another joint (the only one that touched a bit of dirt hence it took awhile to find it). Job approved and done. Thanks to those who responded!
Similar Threads: test ball
Plumbing Forum, Professional & DIY Advice Questions regarding placement of test ball... Jun 10, 2013
Plumbing Forum, Professional & DIY Advice Anyone know of a plug or balloon for an ex. toilet & tub during DWV water test? Jun 12, 2012
Plumbing Forum, Professional & DIY Advice Cherney 2 " test ball shower liner leak test Feb 17, 2012
Plumbing Forum, Professional & DIY Advice Test ball location Jul 14, 2010
Plumbing Forum, Professional & DIY Advice Test ball / balloons? Jun 13, 2010
