How to make a drain viable
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by amateurplumber1, Jul 31, 2013.
  1. amateurplumber1
    amateurplumber1 Member
    Mar 10, 2013
    Here
    Hey all, I just managed to get grate off that was over a drain that I wanted to drain the softener into (thanks for the advice!), but the drain appears to be clogged (hasnt been used in 30 years or so). Is there any way to unclog it? I poured some draino into it but it didnt really seem do anything at all.
  2. MichaelBukay
    MichaelBukay Plumber
    Jan 14, 2013
    CA Plumbing Contractor, Working for the man in CO
    Conifer, Colorado
    try a snake but let the guy know you put draino in it. no one wants that on their skin!:eek:
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Drain cleaner are totally useless on a clogged drain. Might clear up a clogged P trap, but not a drain. It needs to be cleaned by a professional with professional equipment. DIY snakes are mostly a waste of time as they are too small and too short. Even if you could find one to rent, the larger snakes are very dangerous for a novice, in fact they are dangerous for a pro as well.
  5. Terry
    Aug 17, 2004
    The small hand snakes are safe to use.
    It either works, or it doesn't. You're not out much.
  6. hj
    Going through a "P" trap with a snake is always iffy. A small one could just coil up and kink, while a larger one may not make the sharp bend. One of the plumbers tried to snake through a "P" trap one and it felt like he was sending a lot of snake down the drain. When he pulled it out, because he was not clearing the drain, he found the snake has snapped into a lot of 18" pieces when it tried to go around the bend.
  7. amateurplumber1
    Mar 10, 2013
    Here
    Thanks guys. I thought the same thing about the snake (worth a try, but it'd be hard to get down there, and it might break, since I'm pretty positive it's just a p-trap in the floor). I'll still try it, though. I'm gonna try plunging it too. I'd try to stick a garden hose in there but I dont know where I'd attach it in the basement.
    I'm never gonna be able to drain this softener lol.
Similar Threads: drain viable
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Friday at 1:36 PM
Plumbing Forum, Professional & DIY Advice New P Trap drains very slowly. Tuesday at 6:39 AM
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Feb 20, 2017
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Feb 19, 2017
