How to inspect the drain field
Discussion in 'Toilet Forum discussions' started by indika, Jul 3, 2007.
  1. indika
    indika New Member
    May 22, 2007
    Canada
    I bought a cottage recently and I was told by the previous owner that the drain field is not working properly and he has never pumped the tank.
    So Igot the tank pumped, how do I find out if my drain field is still working, I dont want to wait till the tank is full again I want to check the field now. Any ideas?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    As far as I know testing the field requires the tank to be full.
  4. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    Get a copy of the permit for the septic system on your property from the local Health Department (should have a sketch layout on it) to see where the drainfield is located. It should be recorded either in the property owner's name when it was installed, or by the address.
    If there is a problem with the drainfield being clogged up, the effluent will most likely be rising to the surface in spots, instead of being spread out and absorbed into the ground. You can't miss a problem. It will be wet on the surface, stink like a sewer and the grass will be dead or greener.
    You will need a permit to repair the drainfield, if necessary, and the Health Department technician should be able to help you with advice.
    Good Luck!
    Mike
  5. KennyDash
    KennyDash New Member
    Jul 24, 2007
    Look up some images of a drainfield and you will more or less see that they are in most cases just some gravel, pvc pipe and soil. If it is now working and you run into a blockage, no worrry. If the piping from the field to the dbox to the tank are intact, you should be ok. If the drainfeild is blocked with biomat(crap that build up over the years and blocks the digestation in the field), use a powerfull additive to eat the sludg buildup. www.ridex.com and www.roebic.com are known for their light maintenance bacterial additives. www.newtechbio.com has heavy duty cleaners that blast through clogged systems. See what happens when it fills up and if it is clogged, you might want to get it scoped(looked at with a little camera) and then apply treatments depending on your blockage.\
    Good luck
Similar Threads: inspect drain
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Feb 25, 2017
Toilet Forum discussions Replace rear drain with a ground drain toilet Dec 12, 2016
Toilet Forum discussions Another slow draining/bubbling thread Nov 13, 2016
Toilet Forum discussions Drain mystery: What is it? Oct 15, 2016
Toilet Forum discussions TOTO TU451.10-A Drain Valve and THU440-A Sep 30, 2016
