How to Increase Well Water Pressure?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Dean Erger, Feb 10, 2012.
  1. Dean Erger
    Dean Erger New Member
    Feb 9, 2012
    Pottsboro, Texas
    I’d appreciate advice on increasing my water pressure. I have a well system with a very large water storage tank (about 8 ft high and 6 ft in dia., with a 2†outlet pipe). Water from the storage tank goes through a booster pump for pressure, then to a 20 gallon Champion pressure tank (on a “Tâ€) and on to my home. My pressure switch is set at 20/40 psi. My booster pump’s maximum pressure is about 40 psi. If I try to increase the psi of the pressure switch above about 40 psi, my booster pump runs continuously. 40 psi is fine, but 20 psi is too low. 30/50 psi or 40/60 psi would be okay. Constant pressure of about 40 or 50 psi would be even better.
    My booster pump is old and the only visible markings are on the motor which say: MagneTek Century AC Motor, Jet Pump Duty, 2 HP, 230 Volts, 3450 RPM. The pump has been taken apart and inspected and it appears to be in good shape.
    What are the best options for increasing my water pressure?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    What's to say you could not drop a regular submersible well pump in the storage tank instead of using a booster pump?
  4. Dean Erger
    Feb 9, 2012
    Pottsboro, Texas
    Based on my very limited knowledge, your suggestion might be a problem.
    1. If the submersible pump has to flow up and out the top of my storage tank, then I’d have at least 11 feet of exposed pipe from the top of the tank to the ground. There isn’t any electricity near the tank, so keeping the pipe from freezing would be a problem.
    2. Even if the submersible pump can flow out the bottom of the tank through the existing outlet,
    getting it installed sounds like a difficult, and expensive, job.
    My guess was that a new shallow well jet pump would do the job. Maybe something like a 1 hp Red Jacket 100SRJ. It comes with a 30/50 psi pressure switch, but its max pressure is 72 psi. I assume the pressure switch can be adjusted upward to 40/60 psi, but I’m not sure.
    To get a constant pressure, maybe I could add a CSV1 Cycle Stop Valve. I think it has a 50 psi pressure output (again I’m not sure).
    The info from Red Jacket and Cycle Stop appear to conflict, however. The Red Jacket owner’s manual states: “Do not place valves or filters between the pump and tank, other than a fully open gate valve or “full port” ball valve. The most common ball valves are not full port! Most valves and filters will create excessive friction loss and cause “switch chatter.” Cycle Stop installation instructions shows a check valve and the Cycle Stop Valve between the pump and tank.
    So, my questions are:
    1. Is a jet pump the best alternative?
    2. If so, can I use a CSV1 Cycle Stop Valve notwithstanding what the Red Jacket owner’s manual says?
    3. Is there a better solution?
    Edit: In my initial post, when I wrote that I now had a "booster" pump, I didn't mean a particular type of pump. It's actually probably a jet pump or centrifugal pump.
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    The CSV would be fine to use, just move the pressure switch off the pump and place it on the tank Tee.
Similar Threads: Increase Water
Pumps and Tanks Well Forum & Blog. Water is life. Increased pressure with dirty water Aug 16, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Increase water flow/pressure for a well system Jun 21, 2012
Pumps and Tanks Well Forum & Blog. Water is life. How to increase water pressure? Feb 23, 2010
Pumps and Tanks Well Forum & Blog. Water is life. possible to increase water pressure? Sep 6, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Increase well water supply? Aug 13, 2006
