Please see the picture. I have a cement board to green board transition that I'm not sure how to handle.
Per the picture, the tile will go all the way to the ceiling in the tub/shower area and about half way up in the green board area. The tile will wrap around that corner on the bottom.
My initial thought was to put a plastic corner bead on there, but I'm concerned about how the tile would wrap around that corner. I'm worried that the "bead" part will not allow the corner piece to wrap without interference. Plus, filling the gap at the corner will bring the wall slightly out of flat, which may make the tile not not lay flat.
My second thought was just to leave it as is and then run the tile up to the corner just caulk the interface.
My third thought was to put a paper corner bead on there, as it would be flat and not have any thickness to interfere in any way.
Any suggestions/advice?
