How to free a "frozen" joint?
Discussion in 'Irrigation / Sprinkler Forum' started by fishkiller, May 19, 2008.
  1. fishkiller
    fishkiller New Member
    Jan 11, 2008
    I have a crack in one of the (brass?) isolation ball valves that is connected to my pressure vacumn breaker. I want to replace the valve without damaging the PVB, but I can't break the joint free using "brute force". I haven't used WD-40 on it yet, so that's my next step. If that fails, should I heat the joint with a torch? Any other suggestions?
    Thanks for any help - fish
  2. oshawa
    oshawa New Member
    May 19, 2008
    "frozen Joint"
    If all else fails use heat...........
  4. PEW
    PEW DIY Senior Member
    You will get much better results using a penetrating oil like PB Blaster vs WD-40.
  5. Mr_Pike
    Mr_Pike New Member
    Jun 28, 2007
    Use bigger wrenches.
  6. fishkiller
    Jan 11, 2008
    Heat did the trick
    Thanks for the suggestions!
Similar Threads: free frozen
Irrigation / Sprinkler Forum Freeze Tolerant ball valves Feb 18, 2014
Irrigation / Sprinkler Forum Frost free faucet and timer - OK? Aug 11, 2013
Irrigation / Sprinkler Forum will this work for anti-freeze? Jan 20, 2010
Irrigation / Sprinkler Forum Freezing PVC ball valves Aug 13, 2008
Irrigation / Sprinkler Forum Connection Leaking on Frost Free Faucet Aug 11, 2007
