AerixJ
- Messages
- 2
- Reaction score
- 0
- Points
- 0
We returned from a family vacation to find water leaking from the upstairs bathroom all the way down into the basement (and all over my tools!). I was able to get access to the problem area through a built-in cabinet in the dining room and found the problem:
The drain pipe coming from the drain trap is leaking right where it's welded onto the trap. This is an old house -- built in the 20s. The pipe is not fitted onto the trap (unless it's under the weld material?), but appears welded on with what looks like lead. Here's a closeup:
What can I do to fix this leak? It's pretty bad -- you can actually move the pipe a bit where it is supposed to be attached to the trap. I've considered using a patching product called Waterweld, which I've used with luck on steam pipes and such. But this is a pretty big area and a joint to boot.
I'd really appreciate some insight on this. Even if I have to call in a pro, it's helpful to know what I'm dealing with. Thanks.
