How to finish sloped ceiling in steam shower
Discussion in 'Shower & Bathtub Forum & Blog' started by RascalHoudi, Jul 18, 2012.
  1. RascalHoudi
    RascalHoudi New Member
    Nov 7, 2009
    Ontario
    Hi.
    I am finishing construction of my steam shower and need to decide on how to finish the sloped ceiling.
    The shower has kerdi on walls and ceiling, so that limits me to using an unmodified thinset. I emailed Schluter and they told me that I could not use any kind of adhesive and needed to stay with the thinset.
    The walls and floors will be tiled.
    The ceiling is 6' x 4', with a slope along the short wall - a 4" slope for 1" per foot. The ceiling also has 3 protrusions - 2 round lights and a round exhaust fan vent.
    I am thinking that tiling the ceiling will eliminate the benefit of the slope, as water will roll to the end of the tile and then drop - never reaching the far wall. I was considering using 4' t&g cedar for the ceiling (to allow an unbroken path to the far wall so that the water drops can run), but if I'm limited to thinset- that won't work too good with cedar will it? Perhaps I can put a ledge near the top of the tiles to support the cedar?
    Just looking for some ideas that some of you may have on how I could finish this sloped ceiling and prevent water drips in the middle of the room.
    Thanks.
  2. jadnashua
    SOme tile have a squarer edge than others. And, overdressing/washing the grout can make the grout joint to become recessed during installation. If you are real careful about cleanup when installing the grout, it should be fairly flat.
    Adhesives, especially those with solvents in them, could really mess with the membrane! And, I'm not sure you'd like the cedar there anyway. You obviously can't nail it up as you'd compromise the water/vaporproofing. And, no, thinset is unlikely to make a permanent bond with any dimmensional wood. Maybe an epoxy thinset if you really want to go that way. Check with the manufacturers (both Schluter and the epoxy thinset) to see if they'd approve that.
  4. RascalHoudi
    Nov 7, 2009
    Ontario
    Thanks for the replies guys.. this is a great help.
    I find that I'm starting to lean towards tiling the ceiling as it really appears that I'd have to nail/screw the cedar and compromise the integrity of the Kerdi. Even though I could fill the hole with silicone, it just introduces potential failure points that I really don't need.
    From what I read, the threat of drips doesn't really happen until the steamer has been on for about 40-45 minutes, so perhaps it won't be a concern for normal day to day usage. Combined with the ability to lessen the exposure by grouting as close to level with the tile as possible is really making tile seem like the proper solution.
    John.. your comment about not installing fans inside the steam shower is interesting. Since I haven't ordered the door yet, I can still go with a transom and move the fan to just outside the door quite easily. Have you actually seen any installations where they had the fan inside and experienced problems?
    thx/jd
Similar Threads: finish sloped
Shower & Bathtub Forum & Blog Crane 2 handle shower valve body too shallow in finished wall surface May 14, 2016
Shower & Bathtub Forum & Blog Finish Work Shower Plumbing Fixtures Aug 15, 2015
Shower & Bathtub Forum & Blog Valve not mounted deep enough on finished wall - suggestions? Sep 7, 2014
Shower & Bathtub Forum & Blog Finishing up a Kerdi shower questions Apr 6, 2014
Shower & Bathtub Forum & Blog Kohler Tub Refinish or Replace?! Aug 1, 2013
