How to fill drywall gap?
Discussion in 'Remodel Forum & Blog' started by sting88, Jun 9, 2009.
  1. sting88
    sting88 New Member
    Nov 7, 2007
    I'm installing a new bathtub and had to bring one wall closer by sistering some new studs into the wall. After putting the Denshield on, I of course now have a gap at the edge of it and my old wall. I have some corner bead to go on the surface, but how should I fill this gap?
    See photo!
    Parry
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I'm not too good with drywall and such but I would've run the board 90* from what you did and stacked the sheets. That way the length would've been enough to reach the end of your wall.
  4. hj
    wall
    Unless you are going to install an additional sheet of material over that one, you do not have the tub installed correctly. The tub goes against the studs and the wall material comes down against it and over the lip around the tub.
  5. sting88
    sting88 New Member
    Nov 7, 2007
    The photo is decieving. The tub is against the studs. The tub has multiple lips which is what you're seeing.
  6. Agu
    Agu New Member
    May 21, 2009
    Tampa, FL
    Any gap like that will probably fail and show cracking in that humid environment no matter how you patch it. I'd pull off the drywall to the left to the nearest joint/corner and rerock to a flush joint.
  7. Cass
    Cass Plumber
    Nov 12, 2005
    Yup...rerock to the corner...the gap is to large...you could cut at the 2nd stud in , on ctr., and then run to the corner but for the trouble I would just do the whole end of the tub...
Similar Threads: fill drywall
Remodel Forum & Blog "Fill" or just seal foundation/sill plate gap? Aug 20, 2015
Remodel Forum & Blog What is the best drain grate choice for a Kitchen's stove Pot Filler Aug 29, 2014
Remodel Forum & Blog Anyone know how much sand I can mix in sealer to make crack filler? Jul 19, 2014
Remodel Forum & Blog Filling Nails on Trim Mar 25, 2008
Remodel Forum & Blog position of tub filler relative to claw foot tub Jan 27, 2008
