How to eliminate unwanted heads
Discussion in 'Irrigation / Sprinkler Forum' started by lsc87, Jul 8, 2008.
  1. lsc87
    lsc87 New Member
    Jul 16, 2007
    I have two sprinkler heads in two separate areas I want to get rid of. I haven't dug them up yet to see if they're in the middle of a pipe or at the end of one, but what should I keep in mind when pulling them out?
    If the head is cut into a line, do I just pull it out and patch it up with a connector?
    And if it's at the END of the line, what do I do about a stub end line when winter comes and it needs to be blown out? It may not be possible to remove the stub end line all the way out to the connection with the active sprinkler pipe.
    thanks
    Doug
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    The head should just be threaded on. Just unscrew the head and screw on a cap or plug.
  4. Mr_Pike
    Mr_Pike New Member
    Jun 28, 2007
    Nebraska
    If it is the last head on a line at the bottom of a slope, you might want to replace the standard elbow with a lateral drain elbow. It is just a precaution so dead water doesn't get trapped in the zone during winterization.
    The lateral drain will open a weep hole when the pressure in the zone drops under 5-10 lbs. Make sure to surround the elbow with some sort of rock or gravel to give the water somplace to go.
    If it is a saddle fitting, just dig up the head, and place a threaded cap on top the riser. Replace dirt.
