How to drill 2.25" hole in cinder block wall?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TigerDriver, Aug 21, 2008.
  1. TigerDriver
    TigerDriver New Member
    Jul 5, 2005
    Retired
    Salem, VA
    I'm installing a 5-zone drip irrigation system. I'm locating the control valves in my garage, whose walls are concree block with brick veneer on outside.
    The poly pipe is 0.700" OD.
    Rather than drilling five separate holes through the wall, I want to drill a single hole through the concrete block and veneer. The size of the hole needs to be large enough to accept a sleeve of 2" PVC (to protect the poly pipe and to allow for winterization).
    I have a complete set of bi-metal hole saws, but none for cuttng through the concrete block.
    Any recommendations?
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Home Depot rents a hammer drill and core drills that will buzz though in no time and leave a nice clean hole.
  4. TigerDriver
    Jul 5, 2005
    Retired
    Salem, VA
    The nearest Home Depot rental store is about 150 mi. away. I already own a hammer drill and an arbor that holds a 2-1/2" bi-metal hole saw. I was hoping to purchase just a single saw to fit my existing arbor.
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I doubt the bi-metal will hold up long. You need a diamond core bit.
  6. msgale
    msgale Member
    Sep 28, 2006
    i dont think youcan drillthru, although perhaps a diamond bit might work,i don't know anything about them.
    But your hammer drill probably will drillthru, with a regular masonry bit,a series of small holes,then punch out the middle, Not too neat, you will have to patch around your larger pipe to fill the irregualrities.
    or you can buy a cheap harbor freight demolition hammer, for less money than 300 miles of gas, or almost less, and punch ah big hole. Easier than a hammer drill,but still not neat round cuts.
  7. TigerDriver
    Jul 5, 2005
    Retired
    Salem, VA
    Would a carbide-tipped bit stand up? Keep in mind that the voids in the cinder blocks are not filled with concrete, so I only need to to drill through one inner and one outer wall--about two inches in all.
  8. Master Plumber 101
    Master Plumber 101 In the Trades
    Aug 11, 2008
    Wisconsin
    If you can't get a dry core bit you will have to do as you stated drill multiple holes and try to keep it as clean as possible.
  9. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Yes, carbide will work. Not as clean a hole but that's how we did it in the old days.
  10. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
  11. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Yet another reason why only the DIY crowd ever installs lawn sprinkler zone valves anywhere but outside.
  12. Phil H2
    Phil H2 New Member
    Sep 12, 2006
    Tujunga, CA
    Tiger Diver,
    Just a heads up. If you plan on using 2" PVC pipe for a sleeve, it won't fit through a 2-1/4" hole. The outside diameter is 2-3/8"
  13. maintenanceguy
    maintenanceguy In the Trades
    Aug 18, 2008
    Pennsylvania
    If it's just one hole and you're careful to hit a void in the block and not hit one of the webs, you can do this with a hammer and chisel in under 5 minutes. Concrete block is very easy to break with a hammer.
    Punch (or drill) a small hole to get you started and work around the edge of that hole until it's as big as you want.
    I've opened 3'x3' access holes in block with a hammer and chisel lots of times and it takes me longer to haul the broken pieces out to the trash than it does to make a nice square opening.
Similar Threads: drill hole
Plumbing Forum, Professional & DIY Advice Drill a hole on porceleain tile Oct 4, 2016
Plumbing Forum, Professional & DIY Advice Looking for break in buried 4" drain pipe... can i drill hole in top of pipe? Mar 25, 2016
Plumbing Forum, Professional & DIY Advice Drilled hole in PVC Discharge Pipe from Sump Pump Nov 12, 2012
Plumbing Forum, Professional & DIY Advice Best tool to drill 3-5/8 hole in wood Sep 18, 2011
Plumbing Forum, Professional & DIY Advice Drilled a couple holes in vent pipe - remove and replace or caulk Mar 17, 2011
