how to drain water heater
Discussion in 'Water Heater Forum, Tanks' started by rmp123, Apr 18, 2011.
  1. rmp123
    rmp123 New Member
    Apr 18, 2011
    Pennsylvania, US
    I having a new electric water heater being delivered this week and I need to disconnect and drain my current one. I have read a lot of conflicting info on draining the water heater which is confusing. This is what I finally settled on:
    1. Shutoff power to WH and turn off cold water.
    2. Connect hose to drainage valve at bottom of WH.
    3. Turn on hot water tap of any sink (to prevent vacuum in the line).
    4. Open drainage valve.
    Is this OK?
    One last question: Around the perimeter of my basement there is a 2 inch gap between the wall and the floor that looks to be 2-3 inches deep with small rocks in it. Is it okay to drain the WH into this? It's a 50 gallon unit.
    Thanks.
  2. Terry
    Aug 17, 2004
    That sounds good.
    I wouldn't drain the water into the gravel of the basement. Water from the lower part of the heater can smell. At least I think it does.
  4. jadnashua
    You could also open the T&P valve on top of the WH.
  5. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    If the WH hasn't been drained and flushed regularly (and very few get this treatment), there is a pretty good chance that the drain valve will clog up with sediment and prevent the tank from draining, esp if you have hard water.
    If this happens, you can take the valve out altogether, but then water will just flood out of the hole where the valve was -
Similar Threads: drain water
Water Heater Forum, Tanks Water heater has no drain pan, what precautions should I take? Mar 6, 2017
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Feb 21, 2017
Water Heater Forum, Tanks Question concerning water heater drain valve. Dec 21, 2016
Water Heater Forum, Tanks Need help draining a State water heater Oct 26, 2016
Water Heater Forum, Tanks Water heater (and A/C drain line) installation review Aug 17, 2016
