Looks like we may need to replace the sewage ejector pump that handles the basement bathroom. The existing pump has been in place for the 14 years we have had the home, but it seems like the switch is going, etc. Time to do the job. The check valve in use makes a lot of noise so we would like to replace that at the same time with a quiet one.
Here is the problem. The existing setup does not have a valve above the existing check valve to shut off the rest of the 2" PVC pipe above it. As soon as that check valve is tinkered with there is going to be a lot of "action" from that pipe.
So the question is, what is the best way to handle the contents of that pipe when disconnecting the pump and exisiting check valve? Any thoughts? (I assume we will run a LOT of fresh water through that system before starting anything. Its still going to be one of those nastier tasks, though.)
