How to determine number of recessed lights
ctkeebler
Massachusetts
Is there a formula or a electric code to determine how many recessed lights are needed to properly light a room. I'm redoing my basement and want to install recessed lights but dont know how to figure out how many I need so I dont under or over illuminate the place.
Thanks
If you want even lighting, you need several bits of information:
- ceiling height
- angle of spread on the lamp (flood, spot, in-between)
- max spread of the fixture
From those values, you can determine the circle of illumination at the floor. Then, determine the amount of lumens you want and determine if the fixture can handle that size bulb. Different kinds of bulbs will have different amounts of light, and different fixtures will have different max size bulbs it can support.
Some of the better lighting manufacturers have some decent tables and diagrams that show you what's available. But, a formula...no.
Bill Arden
Computer Programmer
MN, USA
www.billarden.com
I made the mistake of using recessed lights
I used 36 recessed cans in a 24x36 area
The problem is that CF bulbs don't last as long in recessed lights.
If I did it over I would use single strip T9 lights.
Low profile, and still more energy efficient and longer lasting.
Mikey
Hansville, Washington
...nor are they dimmable. We call our dining area the "transporter room", because of all the can lights in the ceiling. They can be individually wired to any of 3 dimmers. This allows building a spot of light shaped to the dining room table which can be moved anywhere the table happens to be, or changed in size if the table is shortened or extended with leaves. The other lights are usually kept dim or varied to accomodate the changing whims of She Who Must Be Obeyed.
We use CFs in hallways and other areas where we don't need much light. The CFs intended for use in can lighting seem to last longer than the "ordinary" CFs which in my experience don't last very long anywhere. I'm not sold on them yet, and have chosen to save electricity in other ways. Our electricity consumption is trending downward over time, although the cost is up by slightly over 25% over the last 12 years.
ctkeebler
Massachusetts
- ceiling height
What are the better lighting companies to check? The help at the big box stores were not helpful..
Jimbo
San Diego, CA
Can lights are intended to provide accent lighting and "mood" lighting. They are not the appropriate light source for general area illumination, just by their design. Most of the light manufacturers have photometric charts and data on their websites for your planning.
If you decide to stay with the cans, and want to be flourescent, then definitely get dedicated fluorescent fixtures. The snap in bulbs cost a lot less, and are often horizontal for better light distribution, and the ballast is located away from the bulb for heat dissipation. With screw in bulbs, most at 23+ watts prohibit base-up operation due to the heat.
Speedy Petey
Licensed Electrical Contractor
NY State, USA
I just have to say that I disagree with this.
Done right, recessed lighting can give as good or better general light than anything else.
"Done right" is the key. Anyone can stick a big bright fixture in the middle of the room and call it done. Getting recessed right is a bit trickier sometimes, but can be WELL worth it.
lighting
Recessed lighting in a basement can be difficult because the ceiling, by definition, is usually very low, thus limiting the cone of light from a recessed fixture. This can require a multitude of fixtures to create overlapping illumination at the floor level, and even more to create a semblence of uniformity at a higher elevation, such as a table top.
ctkeebler
Massachusetts
Chris, that looks great were there any measurements you used or was it trial and error?
My basement ceiling is 7 foot 9 finished floor to finished ceiling I was going to make two rows effectively dividing the room in half. Start about two foot from the wall edge and divide the remaining distance equally and then decide how big the can size should be.
Pick a manufacturer...look at their website. It will show the cone of light from various fixtures. You may have to interpolate because your ceiling height is not standard. If you remember some trig, once you have the angle of coverage, you can figure it out for yourself. Each fixture is a little different and will cover a different area. Mood lighting is one thing, craft work and reading require different amounts of light. The angles may be wrong, so placement of both the lights and furniture can be critical. If instead of the big box store, you go to a real lighting store, you can have them help, or look through their catalogs to see what is available. There are so many manufacturers out there, and they all are a little different, there is no one pat answer...tie that into your specific needs and desires, and there are countless possibilities. It may be that the best solution is a combination of recessed, stand alone, and track lights. Maybe indirect with some sofits. Without knowing what you're trying to do, it's a crap shoot.
Chris75
Electrician
Litchfield, CT
I'm an electrician, i've had years of trial and error... :D seriously, what I like to do to evenly light the room is whatever the height of the the floor to ceiling is, that is my can spacing, so if I had 8' ceilings I would space the lights 8' apart, I would start off the wall at 4'. but you have to remember the framing probably will not let you get it perfect so you just have to cheat it in.
I prefer 5" cans, 4" cans are not enough light, and 6" cans are WAY to big a hole in the ceiling, the cans in the picture are made by Lightolier, Good luck with your project.
