Hcw3
I have a softener system with a chlorine injector, a 120gal fiberglass contact tank, a backwash carbon filter, and then the softener.
My question concerns the 120 gal contact tank.
The system has been in operation for 4-5 years now, the installer didn't provide much in the way of a cleanout (only a ½" drain line), and I've never cleaned the iron-precipitate out of the tank. I'm thinking that the sediment may have become caked in there by now, and I might have difficulty simply rinsing the tank out. Is it likely to need 'stronger measures', ie: a high-powered sprayer, or maybe a chemical solution, that will break it up?
Or should just draining the tank be enough?
Thanks for any insight.
