How to clean & maintain elec WH tank
Discussion in 'Water Heater Forum, Tanks' started by CHRPC78, Feb 25, 2010.
  1. CHRPC78
    CHRPC78 New Member
    Feb 25, 2010
    TN
    See adjacent post for title of elec 50 g HW that had hot flow reduced in 5-10 seconds. I should have titled it about how to clean tank but I could not get it changed in the list visible to viewers. Sorry for the inconvenience, I am new at typing these things.
    Local suppy house had alum, tin zinc alloy anodes and the factory offered aluminim only. Factory says the 3 metal alloy is for stinky water, probably sulfur which most people do not have.
  2. hj
    Cleaning the tank is not the problem. Repairing the electrical component(s) is. The anode rod is also not the cause of lack of hot water. My procedure for all my tanks has been;
    1. Install the water heater.
    2. Turn on the water
    3. Turn on the electicity, or
    4. Turn on the gas, light the pilot, and then turn on the burner
    5. Use the hot water for many, many years
    6. Replace elements in an electric heater if they burn out.
    7. Replace the water heater when it eventually leaks.
Similar Threads: clean maintain
Water Heater Forum, Tanks Navian heater clean procedure Nov 24, 2013
Water Heater Forum, Tanks Cleaning 40 gallon water heater with vinegar? Nov 25, 2012
Water Heater Forum, Tanks Cleaning the water heater drain pan line Jul 31, 2010
Water Heater Forum, Tanks cleaning hot water coil? Mar 30, 2009
Water Heater Forum, Tanks New Ruud gas water heater won't maintain temp Mar 14, 2013
