How to clamp/fasten gas pipe to wall
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pghsebring, Dec 2, 2008.
  1. pghsebring
    pghsebring DIY Member
    Oct 23, 2008
    Florida
    Now, i've seen all the rants, i want to point out this piping was here when i moved in.
    What i have is a 7 ft run horizontal of 1/2" pipe across my side wall, then a 6ft drop in the corner, then another 6 ft horizontal (perpendicular to the first horizontal run) across my back wall. Think of it as a 3 dimensional "Z". And not one clamp or hanger on any of it. It feeds the dryer.
    I found J hooks for the top horizontal part, but the other two runs (vertical near a corner, and horizontal near a wall) are offset from the walls about 1-2", so i can't just use normal clamps and clamp them to the wall. How would you fasten these in place? All the walls are CMU.
    Thanks in advance.
  2. jadnashua
    I've used the type of clamp that uses threaded rod into a baseplate that is screwed to the wall, then screws into a clamp that goes around the pipe on the other end. Each piece threads onto the rod, and the rod can be whatever length you need to give you the desired standoff length. Get a couple of those on a section of pipe, and it's not going anywhere.
  4. Ian Gills
    Jul 24, 2007
    USA
    In my house I use 3/4" copper bell hangers, normally used for copper water pipes, for just that purpose. Screwed straight into the wall using a plastic wall anchor.
    [​IMG]
    This stopped my dryer gas pipe from blowing in the wind.
    Isn't life funny when you can use copper hangers for iron pipe but not the other way round?
  5. pghsebring
    Oct 23, 2008
    Florida
    the problem is that my pipes are 2 in or so from the wall...those are way too short, and the reason I have avoided them. unless I put some blocking behind them...
    ....what do the pros do in this case?
  6. BluesMan
    BluesMan New Member
    Nov 8, 2008
  7. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    One word, Unistrut. Do a Google search.
    I would most likely use an angle bracket and piece of strut out from the wall and then the proper sized clips to secure the pipe.
  8. pghsebring
    Oct 23, 2008
    Florida
    I gave in and went with the plates and split rings - 2.50 plus rod per set, instead of less than a buck for a clamp...oh well. I just thought it would be kind of funny on the horizontal run, with the weight of the pipe trying to bend the threaded rod sticking out of the wall horizontaly...but I guess the pipe doesn't weigh that much...
  9. jadnashua
    Have you tried to bend 3/8" steel rod? Especially when you said it only needed to be a couple of inches long?
  10. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Sounds like a job for this guy...
    [​IMG]
Similar Threads: clamp/fasten pipe
Plumbing Forum, Professional & DIY Advice 3/4" pipe for shower system.... Yesterday at 5:59 AM
Plumbing Forum, Professional & DIY Advice Pipe Sizes for Older Water Meter Horn Sunday at 7:40 PM
Plumbing Forum, Professional & DIY Advice Remove PRV and Connect Straight Pipe Friday at 11:29 AM
Plumbing Forum, Professional & DIY Advice Washing Machine Standpipe and Sink Drain tied to one drain? Mar 20, 2017
Plumbing Forum, Professional & DIY Advice bathroom fan vent pipe insulation Mar 20, 2017
