How to change the spinkler pattern?
Discussion in 'Irrigation / Sprinkler Forum' started by jlaplant, Jun 13, 2008.
  1. jlaplant
    jlaplant New Member
    Jun 13, 2008
    Hi have a Rainbird model 21AP00 sprinkler head. It currently sprays at 180 degrees. I would like to do 2 things:
    1. Make the sprinkler head to spray 360 degrees.
    2. Make the spray distance further.
    Can you help?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    A quick Google search shows that the 21AP is a rotary impact head. The RB impacts that I am familiar with can easily be adjusted to any degree of circle you wish, and by simply flipping the wire trip upward will operate full circle. The distance they will throw is regulated by adjusting a screw the the water stream passes. I have not actually seen this model, but I have to believe it would be similar.
  4. jimbo
    jimbo Plumber
    San Diego, CA
  5. jlaplant
    jlaplant New Member
    Jun 13, 2008
    Thanks
    Guys thanks for the information. I figured out that you have to take a small band off the sprinkler while it is on. Once you have that you push down on the sprinkler head and twist it 90 degrees until you find tha pattern you want. It was rather easy once I figured that out. Thanks for the help!
Similar Threads: change spinkler
Irrigation / Sprinkler Forum Backflow device for greywater changeover device Apr 29, 2015
Irrigation / Sprinkler Forum How to change timer on sprinkler system Jun 25, 2012
Irrigation / Sprinkler Forum Sudden Change to PSI: HELP?!? Apr 10, 2009
Irrigation / Sprinkler Forum Pressure Drops When Sprinkler Zone Changes May 4, 2006
