How to attach 3/4" shut off valve to cast iron
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bergs54, Dec 19, 2008.
  1. bergs54
    bergs54 New Member
    Dec 19, 2008
    California
    Hello,
    I am replacing a leaky main shut off valve to my house. I duplicating the exact set up that was there before except I am using brass valves / nipples instead of cast iron. The problem I am having is attaching the 3/4" brass shut off valve to the main water line coming from the city's shut off valve. A small amount of the cast iron (male) threads broke off when I removed the existing shut off valve. Now, I can't get the brass valve to thread onto the cast iron. It almost seems as if the 3/4" brass is too small, but I know a 1" valve would be way too big. Any suggestions for attaching the valve would be great. Also, I can email a picture if need be, but I cant seem to get them to upload to the forum. Thanks in advance.
    Seth
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    The nipple needs to be replaced or, rethreaded. Pipe threads are tapered.
  4. bergs54
    bergs54 New Member
    Dec 19, 2008
    California
    Okay, Thanks.
    What is involved in rethreading the pipe? Replacing the nipple is going to involve a fair amount of digging.
  5. Redwood
    Dec 15, 2007
    Service Plumber
    You would need the proper size threading die. getting it started straight on the remaining threads and haveing the pipe in good enough condition where it can be threaded.
  6. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    By the way, the existing pipe is most likely steel, not cast iron. :)
  7. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Can you use a pipe wrench to unscrew that piece of galvanized pipe and bring it to a hardware store? My local hardware store will cut a new length of pipe to size and thread it for free.
  8. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    you are in trouble...
    How old is that pipe that pipe you are messing with???
    Trying to re-tap a corroded 1935-50 steel pipe comming out of a concrete wall is a daunting task....
    you might get lucky, then again it might be so brittle that it will crumble....
    if you actually attempt this,
    I suggest you somehow try to stabelize the pipe with a wrench or something at the wall so you dont twist or
    disturb the line out in the dirt...
    and use plenty of oil and lubrication on that dye.as you are threading it on that
    old pipe.
    What you are attempting is sort of like doing by-pass surgery.....
    get just a little too rough and the patient dies..
  9. Probedude
    Probedude New Member
    Nov 25, 2008
    CA
    And sometimes even if you do it all right the patient still dies.
  10. theplumber
    theplumber Member
    Dec 20, 2008
    CA
    I'm not exactly clear on where you are working on your line - but. From the city's water meter there is usually a union fitting w/ an attached nipple. From there you attach your water line after that point. If that connection fell apart you may need to call your department of water and power and get a new union to attach to your meter. From there you can attach a valve after that point.
    That is what it sounds like you are having a problem with. The union threads on the meter won't match up properly w/ a 1" or a 3/4" female fitting.
    PS - water lines are usually run in galvanized steel or copper. Cast iron only gets used by the city water lines and is not like the cast iron materials used for water drains and vents.
  11. Master Plumber Mark
    Feb 6, 2005
    the doctor still gets paid...
    Yes, you are right.....
    sometimes no matter what you do ,
    the patient still dies.....
    but just like the Doctor,
    I still hand them the bill..
    without pictures you cant really say
    what this fellow is working with...
    I jsut know he is in it up to his eybrows....
Similar Threads: attach shut
Plumbing Forum, Professional & DIY Advice Shutoff Valve problem (pics attached) Feb 28, 2009
Plumbing Forum, Professional & DIY Advice How do I Extend Existing Waste Pipe In Order to Attach Toilet Flange Mar 4, 2017
Plumbing Forum, Professional & DIY Advice Attaching new PVC drainpipe to copper stub out Mar 2, 2017
Plumbing Forum, Professional & DIY Advice Leaking outdoor faucet attached to house Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Copper pipe too short to attach a coupling and extension? Sep 10, 2016
