How to adjust hot/cold w new shower head
Discussion in 'Shower & Bathtub Forum & Blog' started by joekapahulu, Jun 22, 2008.
  1. joekapahulu
    joekapahulu New Member
    Jun 22, 2008
    My brother built us a new shower which included a single handle for turning on the water. He then went back to Oregon. After sealing the grout etc we are using the shower. The mix of hot to cold water is too much to cold. The other shower which is right opposite of it down the hall is fine. They share plumbing so I am thinking it has something to do with how the single handle works. I cannot find the paqerwork so I am looking for what I need to do to (if possible) to adjust the flow between hot and cold. The fixture is a Pegasus 9000 from Home Depot and of course I cant find any real info on it as it is a HD private brand. Help!
  2. jadnashua
    Assuming the hot is not blocked, most new valves have a mechanical stop to limit the maximum temperature. Yours may need to be set to allow it to mix more hot in. Without the instructions, you'll have to figure it out for yourself, but basically, first thing I'd try is take the handle and cover plate off to see if it is obvious.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Hopefully it is as I recall their website was not very informative on technical details.
  5. jimbo
    jimbo Plumber
    Most showers these days have an adjustable mechanical limit under the handle. Try removing the handle to see what's there.
    For more specific info, go to HD and get a phone number...it is usually printed right on the box. Glacier Bay is always Globe Union. A lot of Pegasus is also, but it could also be Paini or Jiama Lotra....so try to find your model and get the number off that box.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Thats the trouble with Pug-ah-sis at Home Cheapo. A lot of its not really a manufacturer but instead whoever they found to make it cheapest. Without that number and the original parts information no one can tell what you might have. It's not nice like with a real manufacturer like Moen or, Delta.
Similar Threads: adjust hot/cold
Shower & Bathtub Forum & Blog Is it possible to adjust this particular shower mixing valve? Jan 19, 2017
Shower & Bathtub Forum & Blog Help adjust brass tub drain... I'm stuck Jun 30, 2015
Shower & Bathtub Forum & Blog Adjusting Max Temp on Grohe 35015 PBV Apr 27, 2015
Shower & Bathtub Forum & Blog Delta Mix / Scald-Guard - No Volume Adjustment? Jan 2, 2014
Shower & Bathtub Forum & Blog Grohe Mixing Valve for a Talia Shower fixture adjustment. Sep 10, 2013
