How to adapt a 1.25" tailpipe to a 1.5" trap adapter in the wall?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by crust, Feb 25, 2011.
  1. crust
    crust New Member
    Feb 7, 2011
    austin, tx
    I have purchased some new sinks/drains and the tailpipe is 1.25". Coming out of my wall is a 1.5" piece of PVC with the trap adapter solvent welded in place. There isn't enough room to cut it and replace it. So my question ... is there any sort of coupling or part that would allow me to attach the 1.25" tailpipe to the p-trap and then into the 1.5" trap adapter. (Does not matter to me where the adapter goes).
  2. Terry
    Aug 17, 2004
    We use a standard 1.5" trap with a 1.5x1.25 reducer on the top for the tailpiece.
    It's how my p-traps come, with both slip joint washers in case I'm installing a lav or a kitchen drain.
  4. crust
    crust New Member
    Feb 7, 2011
    austin, tx
    Thanks I didn't see the reducer at the HD, so I'll try the plumbing supply in the morning. Or is this a regular PVC reducer (i.e not one of those thin plastics that they make the trap adapter from)?
  5. hj
    Use a 1 1/2" slip nut, or a 1 1/2 x 1 1/4 reducing one, AND a 1 1/2x1 1/4" reducing slip washer, which usually comes with the trap adapter. You should have had one on the old taipiece where it went into the 1 1/2" trap.
  6. crust
    crust New Member
    Feb 7, 2011
    austin, tx
    Thanks for the replies, well the faucet / drain / sink (and rest of bath) are brand new so there wasn't an old tailpiece to use. However, I got the 1.5 x 1.25 adapters (and they did come in the trap adapter kit) from the plumbing supply. But it still doesn't seem right. The faucet/drain is a delta 554 with a chrome tailpipe. I put the 1.25 ring over it and it just fell right off (first sign of a problem) and I went ahead and held it while tightening it, but it was still too loose. Not sure what to try now. So I am going from this chrome tailpipe to a plastic trap adapter and I got the 1.5" kit. So it would appear that my metal pipe is less than 1.25" or I am wrong somewhere else. I did verify that the kit is 1.5" and it is mounted in the wall correctly.
  7. hj
    There is only ONE 1 1/4" tubing, so your washer was bad, not the tubing.
  8. Terry
    Aug 17, 2004
    When it's tightened up, it compresses the washer.
  9. crust
    crust New Member
    Feb 7, 2011
    austin, tx
    Ok, I figured it out, there seems to be a flaw with the washers I had. I got the same brand but from another store and they are slightly smaller and so fit snugly on the pipe. At this point I have done all the plumbing on my new bath and I'm quite happy with the result. Learned quite a bit while I was at it. Probably the hardest thing was figuring out how to adapt regular drains for use on the copper sinks (no overflow). I know there were options for vessel sink drains, but we really wanted to use this one.
Similar Threads: adapt tailpipe
Plumbing Forum, Professional & DIY Advice Faucet adaptor sizing Oct 24, 2016
Plumbing Forum, Professional & DIY Advice Reusing 1" flare adapter Sep 3, 2016
Plumbing Forum, Professional & DIY Advice Looking for 3-inch ABS no-hub adapters in Seattle area Jun 22, 2016
Plumbing Forum, Professional & DIY Advice Question about trap adapter Jun 4, 2016
Plumbing Forum, Professional & DIY Advice Grohe Red Duo (UK Version) works in the US with adapter? Mar 28, 2016
