How tightly should [Gator|Shark]bite fittings be screwed to threaded brass?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by miamicanes, Nov 9, 2009.
  1. miamicanes
    miamicanes New Member
    May 30, 2009
    Computer penetration tester & software engineer
    Pembroke Pines, FL
    Another newbie question that none of the plumbing books in my pile seem to really address...
    my shower valve/mixer is a Delta multichoice rough-in body. It has four male 1/2" brass fittings. To connect it to the PEX hot & cold water, and to the copper pipes for the tub spout and shower head, I bought GatorBITE 1/2" FNPT adapters (Lowe's #211923). I also bought Teflon tape.
    1) How many layers of teflon tape should be wrapped around the threads?
    2) How tightly should the GatorBITE fittings be screwed into the rough-in body's fittings?
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    If it's white teflon I would probably go about 3 wraps around. That stuff is pretty thin. I would strongly recommend using some pipe dope as well as the teflon tape!
    You need to tighten enough so it doesn't leak :p But in all seriousness you just need to snug the fitting on and then go another 3/4 of a turn or so. Just don't crank it on so tight.
    You need to use the right size wrench too. If you use a 12" cresent you don't need to put as much force into it as a 8" wrench.
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    I wouldn't use shark bite fittings in a wall. Use female to pex adapters on the valve.
    John
  5. Cass
    Cass Plumber
    Nov 12, 2005
    It should be tight enough that it won't leak...
  6. hj
    delta
    The Delta valve is design so that the copper tubing slides into the openings and is soldered. THAT is the way a plumber would do it, and therefore, there would be no question about how tight to make it or if it was going to leak afterwards. IF you do use adapters, make them as tight as you can turn them. Do not depend on some formula, such as "hand tight and 3/4 turn additional".
  7. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    But not so tight that it breaks? :)
  8. miamicanes
    May 30, 2009
    Pembroke Pines, FL
    tape over dope? dope over tape? dope on the threads closest to the mixer, tape on the threads furthest away from it? vice-versa?
    In all honesty, I feel more confident of my ability to get a long-term leak-free connection from GatorBite/SharkBite connectors than from crimping or soldering. I've done lots of research on PEX over the past 2 weeks, and learned something interesting about PB... apparently, the failure rate for PB pipes is off the scale in the US, but in Europe they're generally problem-free. It turns out, America seems to be the only place where crimping was a widespread practice. In Europe, Sharkbite-like compression fittings have always been the norm. Even thought PEX isn't PB, I have a hunch that its long-term crimped reliability won't be a whole lot better than PB's was.
    That said, I'm crimping the final connection between the new PEX and old PB, because I've also read some compelling arguments that [Shark/Gator]bites won't be as reliable in the long run with PB, because the pipe wall thickness with PB is thinner compared to PEX, and the insert stiffeners aren't quite thick enough to do the job as securely with PB as they can do it with PEX. There's no inherent reason the stiffeners couldn't be made thicker to accommodate PB as well as PEX, but they don't.
  9. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Do not run pex down to the tub spout. The increased restriction in the pipe and fittings will make the shower dribble when you are trying to fill the tub.
  10. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    I always dope up the threads then tape them.
Similar Threads: tightly should
Plumbing Forum, Professional & DIY Advice How should this humidifier overflow be plumbed? (pics) Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Older septic system runs fuller than it should; how to clear out sediment from lines? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Surface Rust / Cracking at Kitchen Sink hole - Should I repair it or ignore it? Oct 22, 2016
Plumbing Forum, Professional & DIY Advice Valve Stem Leak. Should I be worried? Sep 22, 2016
