how tight to tighten a 1in union
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rrekih, Nov 29, 2009.
  1. rrekih
    rrekih New Member
    Oct 4, 2009
    Canada
    How tight should a 1in copper union be tightened?
    I have 2 that I have tried to tighten to no avail.
    Still very small leak under air pressure test of 40psi.
    I did sweat a threaded adapter to the union.
    The seal looks clean but dis-colored.
    Is there a way to lap the two matting surface's together?
  2. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Are you using any dope?
  4. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    If he is, I'm sure he only puffs, and does not inhale
  5. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    You aren't allowed to use pipe dope on the mating surfaces of a union.
    Sand each surface lightly with some land cloth and don't be afraid to crank the union really tight.
  6. hj
    union
    Now you tell me, after 60 years of doing it. Put dope on the union's faces and the thread for the nut, then tighten it as much as you can. You will not, and cannot, "overtighten" it. Unless you use such huge wrenches that you snap the nut, but that would be VERY hard to do.
  7. rrekih
    rrekih New Member
    Oct 4, 2009
    Canada
    Dam I just thought dope was for doper's.
    I guess I will get to try some soon.
    But I promise not to inhale.
    At least not to much.
    I did use a 14in approx. wrench and did reef on it pretty good.
    There we go with the dope thing again. "reef"
  8. Terry
    Aug 17, 2004
    I don't use dope on the face of the union.
  9. rrekih
    rrekih New Member
    Oct 4, 2009
    Canada
    So some don't some do.
    I am sure if you looked at the manufactures spec. for the union it would state not using pipe dope, probably even give a torque setting.
    I understand the theory behind the union with the flange being the seal point.
    A question, the 2 mating surface's look at lot like the valve and seat in a engine. So in theory if I used a lapping compound and lapped the 2 together I should get a proper seal.
  10. hj
    union
    They were lapped at the factory. Your problem is that you are using A 14" wrench, you need TWO 14 inch wrenchES, so you can tighten the nut while resisting on the other piece.
Similar Threads: tight tighten
Plumbing Forum, Professional & DIY Advice Cannot tighten cartridge after disassembly Wednesday at 9:04 AM
Plumbing Forum, Professional & DIY Advice How and how much to tighten this pipe? Sep 5, 2016
Plumbing Forum, Professional & DIY Advice Properly tighten black steel gas piping Aug 1, 2016
Plumbing Forum, Professional & DIY Advice American Standard 2 knob faucet cartridge - tightening - valve open or closed? Jul 16, 2016
Plumbing Forum, Professional & DIY Advice Tighten a handle, Water Ridge kitchen F. 205674 Feb 17, 2015
