How soon can the vent from a roof drain trap go horizontal?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sethamin, Apr 15, 2013.
  1. sethamin
    sethamin New Member
    Feb 21, 2013
    Brooklyn, NY, United States
    I am replacing a storm line running to a roof drain, and it currently has no trap and connects directly to my main sewer line (combined sewer and storm lines are very common in my area). As long as I'm replacing it, I figure that I should do it properly and add a trap to it. How soon can the vent from this trap go horizontal? I assume that the "6 inches above flood rim fixture" standard doesn't apply here, since the "fixture" in question is presumably the roof, and if you were 6 inches above it, you'd already be vented.
    I'm specifically thinking of having the roof drain drop directly into a trap, then having the vent rise briefly and then jog horizontally to meet up with the main vent.
  2. Terry
    Aug 17, 2004
    If it's on your roof, there is no reason to trap and vent it. The vent would be open air right next to it.
  4. sethamin
    sethamin New Member
    Feb 21, 2013
    UPC 2009 states that all storm drains connected to a sewer line should be trapped:
    And its definition of "Storm Drain" is:
    Granted, I take your point that it's basically being vented anyway. But a roof drain does not extend 6 inches above the roof, nor is there any guarantee that it's at least 3 feet from any window opening. So by my reading of the code, it should be trapped.
  5. Terry
    Aug 17, 2004
    If your roof is not at the top of the building, then are you talking about a "Deck" drain?
    Vents can go horizontal when they are 6" above the flood lever of the fixture, and any other fixtures it's connected to.
  6. sethamin
    sethamin New Member
    Feb 21, 2013
    This particular drain is for the roof of a 2 story extension off the main house (which is 4 stories). But it's part an attached townhouse, so there are neighboring buildings whose windows could be within 3 feet (even at the topmost roof - buildings are all different heights).
  7. hj
    Any vent for a roof drain, which is something I have never installed, would have to rise ABOVE the roof, otherwise when the drain gets plugged the water would simply rise in the pipe until it could flow into the drain system through the vent.
Similar Threads: soon vent
Plumbing Forum, Professional & DIY Advice Do I Need To Replace This Pipe Soon? Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Hot water, sooner Mar 9, 2013
Plumbing Forum, Professional & DIY Advice Dishwasher Rack Rusting - too soon? Feb 14, 2013
Plumbing Forum, Professional & DIY Advice Whole-house filter install soon, planning the loop. Feb 10, 2012
Plumbing Forum, Professional & DIY Advice Hydronic Heating question... need answer fairly soon. May 28, 2010
