How old are these fuses?
Discussion in 'HVAC Heating & Cooling' started by Phillbo, Jul 14, 2009.
  1. Phillbo
    Phillbo Member
    Nov 24, 2008
    Arizona
    If you were to guess, How old would you say these fuse's are?
    Not even sure what the one on the right is .... Should these be in a 5 ton heat pump rated for 50amp? They are 45amp.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Well, I don't think you see Gould fuses any more. I could be wrong, but I think FerrazShawmut bought up that brand.
    Anyway, 45 amps could be in the ballpark for a 5 ton condenser.
  4. Phillbo
    Phillbo Member
    Nov 24, 2008
    Arizona
    So, probably more than 1 year old.
  5. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    I got 24A for a 5 ton heat pump with COP = 3 at 240v. Start up current may be 6x higher.
    Wrap the fuse in several layers of newspaper and hit it with a hammer. If the fuse element inside is only cracked in one place it was a fatigue failure or a mild overload. If the element is splattered it was a heavy overload.
