How often do you need to change the wax rings?
Discussion in 'Toilet Forum discussions' started by mandmmagic, Sep 13, 2007.
  1. mandmmagic
    mandmmagic New Member
    Sep 13, 2007
    I would like to know how often if ever you need to change the wax rings on your toliets other than when you remove them? We ended up having water come through our ceiling from an upstairs bathroom and now the plumber is trying to say that we should have changed the wax ring before now. Is this true?:eek:
  2. Terry
    Aug 17, 2004
    I don't know how you could determine when a good time is.
    It depends on far too many factors.
    In Washington, we leave the caulking off at the back of the bowl, so we know sooner if there is a leak.
  4. mandmmagic
    Sep 13, 2007
    I'd never heard that you should replace them on a regular basis.
    Hi Terry,
    They are trying to say that the repairs are our responsiblity, even though the home is less than 8 years old. They are trying to say that it is a normal maintance item that everyone should do every 3 to 4 years. Since nobody I know has ever heard this, I was just wondering if it was true, or if they are just trying to pull something over on us because they didn't install our toilet correctly. My husband saw when they took the toilet off, that the flange sat about 1/2 below the floor level, and my dad said that it is supposed to sit above the floor level, or else they have to use two wax rings to seal it.
    Who is correct?
  5. Terry
    Aug 17, 2004
    If the flange is below the floor, I use two wax rings,
    Or a thick ring
    Or a waxless seal
    Eight years?
    Most warranties are one year.
  6. jadnashua
    A properly installed toilet should never need the wax ring replaced unless it is removed for some reason. If the toilet rocks in the slightest, it is not installed properly, and it could fail minutes after installation.
    Wax doesn't leak away (a rare exeption might be if hot water ran down the toilet long enough to melt it or there is a heater right behind the toilet, making the whole thing hot). It won't repair itself, though, and doesn't rebound, so if it gets squeezed too thin, then the toilet rocks the other way, it often won't stretch back, so the seal is broken.
    A wax ring isn't like a rubber washer in a faucet. He doesn't have any science to back him up...make him show you something from a reputable source that says you need to change your wax ring on a periodic schedule...he can't.
    A wax ring can fail if the toilet rocks, it is aggressively plunged (blow out), or too much heat, and it melts. Other than that, it should be good.
  7. Terry
    Aug 17, 2004
    Well that is one way. And that wouldn't be an installation problem.
Similar Threads: often need
Toilet Forum discussions how often need change wax ring? affect flushing? rubber rings? Aug 12, 2016
Toilet Forum discussions Toto Drake and water softener Sep 30, 2016
Toilet Forum discussions Toilet Runs Often Jul 26, 2009
Toilet Forum discussions Recs for toilet that won't be used often. Jul 30, 2007
Toilet Forum discussions Need a short toilet base (front) Feb 13, 2017
