How NOT to remove your old kitchen sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Snowman, Oct 7, 2005.
  1. Snowman
    Snowman New Member
    Mar 17, 2005
    Retired math teacher
    FLORIDA
    I did read and search and ask several people before I took on the project of replacing my 18 year old kitchen sink and faucet. Even did a search here on Terry's forum and read all I could about everything to be cautious about.
    I wanted and hoped that I had covered every possible problem that could come up or happen. I knew the drain PVC might need a little modification. However, I had no idea for the following SURPRISE!!
    I read everything that came with 1. The sink, 2. The new faucet and 3. The new grabage disposal. Then I got started. Everything went together like clockwork. sooooo, then the time came to take apart the old sink and move it out to the garage. Here's where I was not prepared, no one warned me and I had read nothing and I guess my common sense is just a little lacking. My wife went around the edge of the old sink to remove the caulk and then my son and I proceeded to remove the old sink.
    First try...... wouldn't move..... I knew the cast iron sink was going to weigh around 140 pounds, so I expected it to be kinda hard to life. Second try nothing. So, my son got down under the sink and pushed up and my wife and I pulled up from above. We pulled harder, and harder................................... (I'll bet you professionals know just exactly what happened next) :rolleyes:
    Well, something went POP and the sink did come up. However all the formica around the sink came up with it. Plus, it didn't just pull up at the seams, it was torn up all around the sink, anywhere from two inches to two feet from the edge of the sink. I was in a state of shock. Nowhere had I read and no one told me about the use of putty or "whatever" under the inside edge of the sink to either hold it in place and/or make sure it kept the water away from the MDF. The instructions on the new sink did not even mention using it. All the instructions said was to caulk around the outside edge. :confused:
    Well, live and learn. :) So now my wife gets new counter tops to replace her worn 18 year old stuff. We are leaving now to see what's out there. I wonder if anyone is around who replaces just the formica surface?? The price would probably be the same. Any suggestions???
    Live and learn, Se ya, Tom
  2. hj
    sink
    That is why we get the "big bucks". Forget about relaminating the tops. Either get new Formica ones or a different material. You used the "If it doesn't move use a bigger hammer" method. We use the "work smarter, not harder" formula.
  4. Terry
    Aug 17, 2004
    OK, I'm laughing now.
    That's why I always go reeaaaaaaaaal slow when pulling those suckers.
    Like that always works when things are glued down real tight.
    But yes, Sometimes you just have to slow down.
    New laminate can go down over bad.
    Or you can take an iron and heat the old stuff off.
    Like hj says though, it may look better with new board.
  5. hj
    laminate
    IF the backsplash is postformed, he will not find anyone who will be able to "mold" the new Formica around the bends.
  6. Terry
    Aug 17, 2004
    This is true.
  7. Snowman
    Snowman New Member
    Mar 17, 2005
    FLORIDA
    Naw, backsplash is separate, but we have found new countertops we like..... Formica makes one now that sure looks like and has a texture of stone.
    Nothing I can do about it now, water under the bridge. I sure thought 140 pounds was very heavy. I had no idea that it was stuck down.
    Is that a normal procedure to stick a sink in place by putting putty and/or caulk under and/or behind the edge??
  8. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    poly-seam -seal is very bad
    I have had to use a steak knife before to
    wedje under the sink and literally saw the sink free
    from the top....
    a serrated steak knife works pretty good with silocone...
    it cuts right through the stufff and you can literally saw
    all the way around the sink , except fo tthe back side.....
    it usually will give with a tender nudje...
    but god help you
    if someone used poly-seam -seal on the top because it will
    almost never --ever come up...
  9. Snowman
    Snowman New Member
    Mar 17, 2005
    FLORIDA
    Thanks Mark,
    Funny, that's exactly what we used (serrated steak knife) to take the formica off the edge of the sink and cut through the caulk or sealent. Of course it was in pieces this time. :)
    Thanks, Tom
Similar Threads: remove kitchen
Plumbing Forum, Professional & DIY Advice how to remove kitchen tap Jan 13, 2014
Plumbing Forum, Professional & DIY Advice How do I Remove kitchen faucett? Sep 14, 2011
Plumbing Forum, Professional & DIY Advice Kitchen Faucet Moen 7730 - how to remove handle Aug 25, 2009
Plumbing Forum, Professional & DIY Advice How to remove this kitchen faucet? Sep 9, 2008
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Monday at 9:32 AM
