How much water in the tank? eg. Korky valve
Discussion in 'Toilet Forum discussions' started by bnbhoha, Dec 6, 2005.
  1. bnbhoha
    bnbhoha New Member
    Jul 9, 2005
    Illinois
    I'm getting ready to install some Toto Ultramaxs. Since these are low flow toilets and the purpose it to conserve water, I wanted to make sure I made the correct adjustments. How much water do we actually allow in the tank portion of the toilet? From my unlimited experience, when I used to replace these valves, I could fill the water almost to the top until it fell threw the "big tube". I want to make sure I have the correct height. Is there one? Thanks
  2. jadnashua
    Normally, the fill valve is already installed and adjusted on Totos. If not, or it is not adjusted properly, the water should come up to the mark on the tank. Note, when it becomes necessary to replace the flapper valve, try to get an exact replacement - some of the aftermarket ones either close early or late, compromising the flush or wasting water.
  4. Terry
    Aug 17, 2004
    The Toto Ultramax and the Toto Drake come adjusted from the factory.
    Of the thousands I've sold, I've never bothered to change the factory setting.
Similar Threads: much water
Toilet Forum discussions NooB Question: Why are WaterSense toilets so much cheaper than standard toilets? Aug 18, 2010
Toilet Forum discussions Not much water in toto drake toilet bowl How do I resolve this Jun 20, 2006
Toilet Forum discussions Too much water during flush Feb 26, 2005
Toilet Forum discussions Elevated water chamber cases too much pressure Feb 1, 2005
Toilet Forum discussions Wall Mount: How Much Wall? Mar 14, 2013
