How much mortar base
Discussion in 'Shower & Bathtub Forum & Blog' started by rdykes, May 22, 2006.
  1. rdykes
    rdykes New Member
    May 22, 2006
    I have a Maax Studio 3 piece bath/shower with roof cap waiting to be installed. The directions are too general to be sure of proper installation. Specifically, the base of the tub rests on a sheet of wood which is supported by a wood "runner" and the front of the tub. The tub base has about a 2 inch clearance to the floor. The directions say to lay a mortar base before setting tub. Does that mean we goop it up between the tub base and the floor? If so, does the wood runner get set in the structolite as well? Not many of these have been installed in our rural area. Thanks for your input in advance.
  2. Terry
    Aug 17, 2004
    The front apron would set on the floor,
    The rest of the base can be supported by mortar.
    I find it best to have a few lumps of mud that will squish out.
    If you try to guess how much to put down and you lay it out solid, it could be too much and the base won't get down to the floor.
    If the wood runner is in the air, it can be supported.
Similar Threads: much mortar
Shower & Bathtub Forum & Blog Sterling Ensemble how much mortar? Aug 19, 2010
Shower & Bathtub Forum & Blog Problem fitting tub into alcove (too much extra room) Jan 15, 2017
Shower & Bathtub Forum & Blog How much "out-of-square" is OK? May 12, 2013
Shower & Bathtub Forum & Blog Showerhead prssure is much lower after returning from vacation Aug 29, 2011
Shower & Bathtub Forum & Blog Reversing tub drain- how much can I add to existing drain pipe? Jul 8, 2011
