How much gravel for 12x52 tank ?
DuckyDucky
Ontario
Hello, I'm replacing bed in my 12x52 tank, how much gravel do I need... do I just cover the basket or it should be higher then that ?
Thank you
ditttohead
Water systems designer, R&D
Ontario California
several schools of thought, all really don't matter all that much but...
cover screen plus three inches...
or
fill the dome (as calculated but most tanks are not true to the shape...)
or
20#
Nicely done REACH.
DuckyDucky
Ontario
Thank you to both of you
Looks like I will need more... I will find it locally but wath mesh size gravel should I get ? Any ideas
I have only 25 lb .
. And two 12x52 GAC tanks!?
ditttohead
Ontario California
1/8", #6 is preferred but... non nsf listed gravel... be careful. A lot of gravel can have serious impurities including arsenic, organics etc. since it is not typically intended for potable water
DuckyDucky
Ontario
Thank you, looks like my local plumb supply store caries
So I guess the Red Marking is the one ? 1/8 in. x 1/16 ?
A7005A Gravel #20 1/8 in. x 1/16 in., red marking
A7006A Gravel 1/4 in. x 1/8 in., orange marking
A7007A Gravel 1/2 in. x 1/4 in., black marking
Good tip about NSF
